Old 08-11-2007, 11:57 AM   #1576
badboy's Avatar
Trader Rating: 14 (100%+)
will the 3200 li-poly finish a 5 min race using 7t brushed motor or 3.5t brushless? thanks
badboy is offline   Reply With Quote
Old 08-11-2007, 12:28 PM   #1577
J@UNE's Avatar
Originally Posted by aus jd 2703 View Post
so i just got 2 3200 and wonder should i chase a balancer?
Well so far one racer have one. I bring him a coffee and he let me use his
J@UNE is offline   Reply With Quote
Old 08-11-2007, 01:34 PM   #1578
SWTour's Avatar
If it's NOT overgeared...it will
If it doesn't...it's overgeared....LOL
SWTour is offline   Reply With Quote
Old 08-11-2007, 02:34 PM   #1579
SkeeryJones's Avatar
i use a 6.5 and use about 1700mah, around another 400mah is useabale before it would go below 6v. so if u can resist doing warmup laps, then you may just be ok
SkeeryJones is offline   Reply With Quote
Old 08-11-2007, 05:34 PM   #1580
Originally Posted by VooDooPH View Post
anybody tried using the trakpower balancer on the orion packs?
Not yet, but have thought about getting a trakpower balancer 'cause they have the same balance port to the orions.
While Im here, i have a mamba 4600, orion 3200, i had it on auto cut-off. usually when it gets low, you can hear it power down and eventually the cut-off kicks in. the last few runs i have noticed, when its close to powering down, it stuttered, then it just cut-off. Do you think me lipo needs a balance, or its the esc? I have my cut-off now set at 6V...
Drift Demon is offline   Reply With Quote
Old 08-11-2007, 06:17 PM   #1581
syndr0me's Avatar
Trader Rating: 32 (100%+)
The TrakPower balancer looks like it's a Hyperion LB6 already wired for the Orion/TrakPower style balancing. Orion's SBS also seems to be based on the LB6 (lots of balancers are), but you have to make a connector for it.
If you get a balancer based on the LB6, you can buy harnesses for it that work with just about style of pack.
syndr0me is offline   Reply With Quote
Old 08-12-2007, 06:49 PM   #1582
ok whats a good versatile balancer to do reciever packs race packs and controller packs?
i dont mind making harnesses as long as it can do 4s packs?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 08-13-2007, 06:10 AM   #1583
orion, great planes, flightpower all have balancers. they are all the same in different packaging.
Old 08-13-2007, 10:02 PM   #1584
peded's Avatar
I also have a few questions about lipo before I consider switching.
I presume the Duratrax Ice is capable of charging such batteries. What charge rate would you reccommend for charging?
I normally run down at a Hobbytown Race and we have 2 qualifiers and 1 main. The qualifers are 4 minutes each and the main is 5 mins. So in total its 17 minutes of racing plus practice so about 25-30 mins total.
Would this Orion 3200 be able to run on a single charge or would you reccommend charging in between runs?
Xray T2 US '007, JR Z590 servo, KO PROPO EX-10 Helios, Novak GTB, Novak 13.5, EP4600?, Orion Advantage.
Sportworks Recoil - MMR Spec, GTX
Additional Feedback: http://rctech.net/forum/showthread.php?t=145047
peded is offline   Reply With Quote
Old 08-13-2007, 10:07 PM   #1585
r0adrunn3r's Avatar
Send a message via MSN to r0adrunn3r
The ICE charger is fine (that is what I use). Just set it to LiPo mode 7.4V and the capcity to 3200mah.
As soon as I finish a race, I put it on the charger. Just put it straight on. It is too easy!!!
It is best to charge between races as you don't want to over discharge them.
r0adrunn3r is offline   Reply With Quote
Old 08-13-2007, 10:21 PM   #1586
sportpak's Avatar
Trader Rating: 26 (100%+)
Has anyone tried using one of the Much More battery warmers? I hear these batteries are at peak performance at 100F. I don't want to lug around a bunch more stuff, but I am curious. Any advantage I might find...you know......just curious.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 08-14-2007, 08:13 PM   #1587
sportpak's Avatar
Well, I ordered the warmer setup to experiment with on these batteries and some nimh I use in my 12. I'm stuck going to the caribbean next week so after that I'll play around with it. I try posting some results on here, noticable or not.
Old 08-14-2007, 08:18 PM   #1588
so has orion said we can safely charge at 2c?
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 08-17-2007, 04:27 AM   #1589
This Question has probably been asked but : I just got an Ice Charger and a 3200 Peak lipo. I wanted to get a balancer but the hobbyshop said the pack did not need one. However I did notice last night that here is a small hole that says equalizing. So what type of balancer do I need to get and will it go inline .Or what will I have to do to make one go in line (if possible?) I previously had a 4800 that would not fit in my TC.So it's been several weeks trying to get all this stuff together and fitting into the car (RDX PHI).The 3200 are still a tight fit but it will work. Another question is it safe to plug the ESC directly into the battery.I plan on making a pig tail to keep the esc wired and a plug to charge the battery. I'll never have to remove either plug.I've ordered the Corally plugs that fit the batteries.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 08-17-2007, 05:47 AM   #1590
NIP Team Orion 3200Mah Lipo Race Pack limbohz R/C Items: For Sale/Trade 0 05-30-2008 10:36 AM
Peak 3200mah carbon spec lipo aus jd 2703 Australia For Sale/Trade 8 04-23-2008 09:12 PM
Team Orion Carbon Edition 3200mAh LiPo squearl R/C Items: For Sale/Trade 7 03-11-2008 06:35 AM
Team Orion Carbon Edition 3200mAh lipo batteries dido41 R/C Items: Wanted to Buy 3 07-26-2007 04:10 PM
2 Team Orion Carbon Edition 3200mAh LiPo Batteries CCristo R/C Items: For Sale/Trade 1 05-04-2007 11:48 AM
