ESC Caps for Quantum/NOSRAM >
Old 01-27-2003, 08:01 AM
  #16
I am fairly sure that the LRP/Nosram caps are Panasonic FC Series .
MattW is offline
Old 01-27-2003, 08:34 AM
  #17
you could be right, the only people who know for sure is LRP themselves.
sanj
schumacher is offline
Old 01-27-2003, 11:39 AM
  #18
Let's put it this way. Physically the same size, capacitance within expected tollerance, End caps identical........hmm
MattW is offline
Old 01-27-2003, 07:14 PM
  #19
imataquito's Avatar
yes forgot to add .. panasonic FC series....
imataquito is offline
Old 01-27-2003, 07:16 PM
  #20
imataquito's Avatar
ELNA is also good ... specs are better then rubycom
Old 01-27-2003, 11:20 PM
  #21
Tom
Tom's Avatar
nosram has a low forward rated current(140amps) to the lrp(238amps)
Tom is offline
Old 01-28-2003, 09:26 PM
  #22
Registered User
How exactly would you wire one of these caps in?
I have an old Tekin I would like to try this with.
Would Radio Shack have caps that would work well?
-Tom
TommyGun43 is offline
Old 01-29-2003, 05:34 AM
  #23
yeah Radio Shack will be fine. just go in and ask for high frequency, 10v working voltage and low impedance. and you pick your capacity.
you solder the positive leg of the capacitor the +ve end of your speed controller, and the negative to the negative. the grey stripe on the cap indicates negative leg. If no grey stripe, its usually marked.
sanj
