need help! how to loose old foam tire for xray m18 >
Old 07-31-2006, 02:19 PM
Default need help! how to loose old foam tire for xray m18
my old foam tires are fade, and i want to change it. but they stick on the inner wheel, cant loose it. any method to loose the inner wheel? thanks
adykahung is offline
Old 07-31-2006, 02:27 PM
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
drill a hole in the center of your outter wheels, unscrew your inner wheel, and then try to take it off when they are off of the car.
HotrodHopkins is offline
Old 07-31-2006, 02:37 PM
vtl1180ny's Avatar
adykahung, there's an 18th scale forum on here....
vtl1180ny is offline
Old 07-31-2006, 02:38 PM
good idea. but can i still use the outter wheel? coz i still want to use it for other set of foam tire
Old 07-31-2006, 02:41 PM
R.Dalnogare's Avatar
you have to pull it and squeeze. it takes a while but you will get it
R.Dalnogare is offline
Old 07-31-2006, 02:43 PM
yeah, you can use the outter wheel.
the only thing about just forceing it off is that you can strip the screws out of the wheel or the universals.
