batteries rubbing
Do you add anything to prevent the batteries rubbing? Do I need to worry about them?
http://img483.imageshack.us/img483/4210/battcs5.jpg |
Usually, you should sand the slots down to prevent any rubbing of the cell packaging. Also, CA glue on the chassis slots to prevent short circuits. I even used some electricians tape and wrapped it once around the slots to be double sure.
I think its 2mm fiberglass not carbon fiber I’ll put a 5mm bit of electrical tape between each battery.
is fiberglass way heaver than carbon http://img301.imageshack.us/img301/2097/carfiberiu1.jpg |
Fibreglass is lighter and probably more flexible. Sanding may not be a good idea, you dont really want all that floating round, mind the same could be said for carbon fibre
I always thought carbon fiber was lighter and stronger :confused: Anyway you learn new things everyday :nod: :D |
