Help with GTB Brushless/brushed esc >
Old 07-28-2006, 09:01 PM
keachj06's Avatar
Default Help with GTB Brushless/brushed esc
i connected my Cobalt 27 pro today using the y method and it doesnt run. the red light is solid and the green one blinks. i have steering but no motor.
when i plug in the white thing i think its the harness for the brushlesss only then it will run. why is that and why isnt my cobalt running.
keachj06 is offline
Old 07-28-2006, 09:45 PM
olhipster1's Avatar
Trader Rating: 100 (100%+)
Default GTB
Go over the setup steps...over and over in your head..before you try and do the actual setup....it took me a while to get the right sequence right..
but if you're in doubt..grab another brushed motor and try the setup with that..just to see if it's the motor (doubtful)...
The sequence of lights is a bit tricky the first few times..but once you get use to it becomes second nature. Hope this helps. cross your fingers and hope it isn't the controller itself.
olhipster1 is offline
Old 07-28-2006, 10:23 PM
keachj06's Avatar
i did and it still doesnt work i even re did it twice
keachj06 is offline
Old 07-28-2006, 10:29 PM
rcgen's Avatar
When switching from bl to brush or vise versa you only have like 3 seconds to hit the setup button.
rcgen is offline
Old 07-29-2006, 06:49 AM
Trader Rating: 206 (100%+)
When that happens you are still in brushless mode. The GTB really sucks when it comes to programing
dodgeguy is offline
Old 07-29-2006, 06:31 PM
Drewdc90's Avatar
It's pretty easy to program it, you just have to read what you have to do then do it, don't read while you do it as it doesn't give you much time to press the set button.
Drewdc90 is offline
Old 07-29-2006, 07:32 PM
Trader Rating: 38 (100%+)
Easy to program but hard to determine which mode you are in. The Sphere Comp makes this task much easier. Anyway Im with Dodgeguy. Probably in the wrong mode.
or8ital is offline
Old 07-29-2006, 07:51 PM
Tim great racing today man. I had fun. Skip the wedding next weekend and race with us.
dodgeguy is offline
Old 07-29-2006, 09:29 PM
Drewdc90's Avatar
When in brushless mode and a senor is not connected, one of the leads blink like what keachj06 described. So probably in the worng mode.
Drewdc90 is offline
