Old 08-01-2006, 09:26 AM   #16
Send a message via ICQ to AU-YONG Send a message via MSN to AU-YONG
Does anyone can give comments on GM Brushless ESC Genius 95?
Does it good?
AU-YONG is offline   Reply With Quote
Old 08-01-2006, 03:10 PM   #17
pheyhoe's Avatar
R/C Tech Charter Subscriber
I was looking to get a brushless system for modified indoor but it seems lots of the racers are having problems with the thing overheating. Does the fan on the sphere really make enough difference to stop it shutting down?
So which motors have the new style rotors or whatever? if i was to get a 3.5 novak motor and a sphere speedo with a fan would that be an ok combo for modified? i would not be running the 3.5 at max power.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 08-01-2006, 04:31 PM   #18
Drewdc90's Avatar
If you are not going to run the motor at max power then you should get a different motor. A 5.5 would probably be enough for indoor. I run mod with my 5.5 and 4.5 outdoor and the 4.5 is somtimes a but much for some tracks. I think the 4.5 would be a bit much for indoor depending on the size.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-02-2006, 04:08 AM   #19
pheyhoe's Avatar
Does the 5.5 have the updated End cap and rotor?
Old 08-02-2006, 04:48 AM   #20
Drewdc90's Avatar
The 5.5 has the updated end cap (if you mean the endbell) and the updated rotor.
Old 08-02-2006, 05:22 AM   #21
MadMikeB's Avatar
Howdy,
I can't comment on your 1/12th, but I have some observations which may be of interest regarding your 2wd off-road. I am currently running a Novak GTB/Velociti 5.5 combo in my T4. I've had it about 8 months. For anything other than a very large track it is simply too much motor. At our home track I can only make full throttle generally in only two or three places on the track, for a total of probably a couple of seconds per lap. On a tight layout with low traction, it is so hard to get the power down I sometimes can't even lose the stock guys :-(
I knew the 5.5 would be over the top, but I'm not real serious about my truck racing, so I went for the overkill/fun option. If I was fair dinkum, I would go for the 6.5 (max) or probably the 7.5 for a truck. For a buggy, the 7.5 I think would be absolute tops. As a comparison, I am often racing close to another T4 guy with a 12x2 cobalt, and I can totally roast him on the straight unless I make a mistake on the entry corner.
Problems? The cooling fan blades all snapped off in no time at all. I ran for a month without a fan, then mounted a AE fan on the chassis next to the GTB. If your buggy is a B4, then I can advise that the GTB won't fit under most shells unless you remove the fan. My experience is that the system is totally fine without the fan at all, and you can simply pull it off.
I can't comment first hand, but I would be very surprised if the fan were required with 4 cells in a 1/12th.
In the the T4 I can easily do 8 - 10 minutes runtime on the track with good 3800's.
Personally I love my GTB/Velo so far.
HTH
MIKE
Originally Posted by crusty
Hi guys i want to get a brushless setup but dont really know what i should do. I run 1/12th and 2wd off-road. Heard the gtb might not clear under the 1/12th scales body.
But anyway here the choices- LRP sheare ,Novak GTB, the new Mamba, or wait till the brushless tekin arrives.
Any help on what i should go with would be great
thanks chris
MadMikeB is offline   Reply With Quote
Old 08-02-2006, 10:20 AM   #22
pheyhoe's Avatar
Yeah i meant the endbell but thought it might have been referred to differently than a brushed motor
Thanks,
Old 08-02-2006, 03:56 PM   #23
Drewdc90's Avatar
Well the endbell on a brushless motor is were the sharft exits the motor. The motor doesn't have the solder tabs like on the 4.5 if that was what you meant.
Old 08-02-2006, 04:39 PM   #24
rampal's Avatar
Send a message via MSN to rampal
I've just get my 5.5r and it does come with the new solder tabs like the 4.5 but no ribbed can.....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 08-02-2006, 05:32 PM   #25
Charlie's Avatar
Well, if it was me. I'd get the GTB with a Velociti motor, but I'm a little biased I suppose.....
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 08-02-2006, 06:35 PM   #26
danjoy25's Avatar
Trader Rating: 37 (100%+)
Are there any improvements to the GTB to handle the hotter motor?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-03-2006, 12:49 AM   #27
Drewdc90's Avatar
It probably doesn't need any.
Old 08-03-2006, 01:52 AM   #28
Send a message via Yahoo to rc10gt_100
mamba max lol
rc10gt_100 is offline   Reply With Quote
WTT/WTB 1/18 Mamba Sytem rswartz R/C Items: Wanted to Buy 0 02-13-2008 08:32 PM
rc18t w/brushless sytem super cheap slowpokeRRR R/C Items: For Sale/Trade 3 03-17-2007 07:00 PM
Brand New: Complete Brushless Sytem D199 R/C Items: For Sale/Trade 1 03-06-2006 03:17 PM
novak ss5800 brushless sytem for sale hpipro321 R/C Items: For Sale/Trade 5 03-15-2005 07:55 PM
WTB: Novak 5800 brushless sytem WheelNut R/C Items: Wanted to Buy 2 01-01-2004 07:55 PM
