Old 07-26-2006, 11:53 AM   #1
Default weight question
I'm curious. They always say that less rotating mass is faster. How does it affect the car if you take weight say off the drive shaft and then add the same amount to the steering rack? Is the car faster or does adding it back to the total weight of the car negate the benefits? I'm asking cause my car is a bit light and I'm debating where to add the weight. I can add alloy parts for durability in say the suspension or to the drive system.
porschejim911 is offline   Reply With Quote
Old 07-26-2006, 12:46 PM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
you won't notice it, but don't add it to anything rotating. that's just sound practice. beef up whatever you feel is breaking or weak, and then put the rest on the chassis to keep it low. consider also, that your suspension needs to react quickly to increase it's effectiveness.
you may find more detailed information here:
http://www.rctech.net/forum/showthre...ghlight=weight
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-26-2006, 12:57 PM   #3
Diggity's Avatar
Trader Rating: 29 (100%+)
YES, less rotating mass IS faster and will have less friction on the endpoints and will help give your car more punch! Any time you move weight around on your car you will have a different reaction, unless its just a tiny bit of weight? If you keep the weight low as (seaball said) you will have the best luck and I agree to keep the weight on the suspension for better durability but dont add any to the drive system
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.teamscreamracing.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
HOW MUCH WEIGHT DO I NEED TO ADD F N CUDA Electric On-Road 3 09-01-2007 12:50 PM
Quick question about motor weight Blin Electric On-Road 2 06-12-2007 01:39 AM
weight question BadSign Micro and Mini Scales 0 07-27-2006 10:34 AM
weight of pt Xrayskid Electric On-Road 3 01-07-2006 04:46 PM
Weight CHR15 Electric On-Road 1 02-03-2004 11:01 AM
