Old 07-26-2006, 12:08 AM   #1
cyber3d's Avatar
Default Deans pigtail on conditioner board. Will it work?
So, Some of my 6 packs were soldered in reverse order ie:
I use an LRP Battery Conditioner Board (if you have this board you know the tabs are not very long) But, I figure my reverse order is no problem since I would use a Deans connector (pig tails) connected to the far left neg and far right pos terminals.
Then just plug in to any order six pack.
Does this not work?
cyber3d is offline   Reply With Quote
Old 07-26-2006, 04:50 AM   #2
Suspended
Trader Rating: 14 (100%+)
Uh, no, that won't work. The circuit(s) is(are) not complete. The point is to discharge each cell separately, so they retain their match as much as possible. You'll have to change your batteries.
Phatkat is offline   Reply With Quote
Old 07-26-2006, 04:50 AM   #3
Suspended
Also, this is in the wrong forum.
Old 07-26-2006, 11:16 AM   #4
cyber3d's Avatar
Hi. Thanks for the advice.
Question: which forum should this be in?
cheers, Victor
Old 07-27-2006, 09:55 AM   #5
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I moved it to the Electric forum for you.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-27-2006, 09:58 AM   #6
combustible's Avatar
If the battery bars you soldered the wires to aren't too tall, you can try just putting the battery in upside down and the polarities should match up
combustible is offline   Reply With Quote
Old 07-27-2006, 10:03 AM   #7
jaz
Can't you just flip the battery pack around so that the side with the pigtail is up against the board (with the pigtail pulled out the top so it's out of the way)? If the tabs on the discharge tray aren't tall enough to reach the contacts on the individual cells when it's in thie orientation maybe try wedging some of those spare battery bars you have there vertically between the cells and the tabs on the discharger. There is assuredly an easy solution without resoldering your packs.
jaz is offline   Reply With Quote
Old 07-27-2006, 07:44 PM   #8
cyber3d's Avatar
Yes, I tried to flip the pack but the end tabs were too long (even bent them and still didn't fit) So, I decided to flip the tabs to the correct direction - the lables are facing down but no one cares. Man, I need a lot of solder practice! butt ugly!
Victor
WTB: Deans Prewired Female Pigtail Peter_PaP Australia Wanted to Buy 3 06-01-2008 02:28 PM
Serpent starter box,Deans discharger,Deans battery jig,Indi battery equalizer SRAD R/C Items: For Sale/Trade 5 03-14-2007 05:32 PM
How do starter boxes work? Do they work with Shaft Start engines? Ofna_Driver_777 Electric Off-Road 7 02-25-2007 07:51 PM
Tweak Board, Set Up Board, Power Supply, Charger, Temp Gun nikos2002 R/C Items: For Sale/Trade 17 08-06-2006 10:45 PM
Novak Pit Wizard with adapter pigtail sands R/C Items: For Sale/Trade 3 02-16-2004 09:24 AM
