Adding an ammetre and volt metre to distrubution box? >
Old 07-28-2006, 04:41 AM
  #16
XrayFK's Avatar
You might want to start making these and selling them, before a company like Much More steals the idea and sells them.
XrayFK is offline
Old 07-28-2006, 04:45 AM
  #17
Nicadrauspro4's Avatar
Yeah, I know they will copy it or some other manufacturers will. I will build the other model with both Volt & Amp readout first and post the pics soon. PM me if you like to order. Thanks!
Nicadrauspro4 is offline
Old 07-28-2006, 08:01 AM
  #18
2-Bad's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Nicadrauspro4
- Built-in replaceable fuse (150A) - Helps protect your equipments (chargers, dischargers, motor cooler, tire warmer, etc.) from getting busted due to short circuit.
I too am a little perplexed by the use of 150A fuse. 150A short circuit current will do a lot of damage to said chargers/motor coolers, etc. Can I suggest that what ever your Power Supply is rated at, your fuse protection should be around 125% of that? For example, if your PS is max 10amps, your protection fuse typically would be 12.5 - 15 amps. What do you think?
2-Bad is offline
Old 07-29-2006, 05:41 AM
  #19
hey can i geta ciruit diagram??just seems a little daughnting at first
aus jd 2703 is offline
Old 07-29-2006, 08:17 AM
  #20
XrayFK's Avatar
He posted a picture of the wiring. It's very simple, positive to positive, negative to negative, just like if you were measuring the voltage with a voltmeter.
XrayFK is offline
Old 09-09-2006, 06:18 PM
  #21
how do u put led's on the power switches to tell u when the switch is on? also arnt led for 3v so 12v will fry em what do u do so u dont fri the led's?
cheers guys
Old 09-09-2006, 08:13 PM
  #22
Rainman40's Avatar
cheers guys
You wire a resistor inline to drop the voltage, places like Radio Shack sell led's in a variety of styles with the resistors prewired.
Rainman40 is offline
Old 09-09-2006, 09:16 PM
  #23
cheers rain man
Old 09-09-2006, 09:43 PM
  #24
what type of capacitor should i put in my distrubution box to stop and voltage spikes? just hear that some cheap power supplies like mine still have a ripple what type and where should i put it?
cheers
Old 09-10-2006, 01:57 AM
  #25
Jochim_18's Avatar
Just get a Ripmax power supply small and compact with amp readout very good power supply... And it will not cost you an arm and a leg. I paid $85 it a 13.8 Volts and puts out 20 AMPS...
Jochim_18 is offline
