Old 07-24-2006, 07:32 PM   #1
Glowster21's Avatar
Trader Rating: 116 (100%+)
Default Helios Problem
I just switched from an M11 to a Helios and am having a problem with the Steering Balance. The Radio won't access the Left Steering Balance. Anyone else had this problem?
Glowster21 is offline   Reply With Quote
Old 07-24-2006, 07:47 PM   #2
Still Bill's Avatar
I assume that you know to turn the steering wheel FIRMLY to the end of its travel to adjust the Steering Balance. For some reason, I do have to turn harder in the left direction than the right on my Helios.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-24-2006, 08:00 PM   #3
whynot's Avatar
Trader Rating: 18 (100%+)
Yep same for me. just turn a lil harder and it will adjust. good luck
whynot is offline   Reply With Quote
Old 07-24-2006, 08:13 PM   #4
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
I had the same problem when i switched from an xray evo2 and bluebird servo to an xray T2 with a futaba s9550 servo.
!xray!
Got Xray? is offline   Reply With Quote
Old 07-24-2006, 08:20 PM   #5
Trader Rating: 244 (99%+)
Do a VR adjustment on the radio and it will fix your issue.
Fred Perkins is offline   Reply With Quote
Old 07-24-2006, 08:22 PM   #6
Still Bill's Avatar
When the function is ready to accept +/- steering balance adjustment changes, you will see an asterisk ("*") next to the words LEFT and RIGHT.
Otherwise, if you have to adjust the LEFT and RIGHT steering balance function with anything more than 10% difference, I would also suggest that you check the steering geometry of your car.
Old 07-24-2006, 08:32 PM   #7
HarshGuy's Avatar
Yep, I had the same issue, and did the VR chingadera thing and viola ...problem solved.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-24-2006, 08:50 PM   #8
Still Bill's Avatar
You just love saying chingadera...
Old 07-24-2006, 08:51 PM   #9
Glowster21's Avatar
What is a VR adjustment? No problem going into the right balance. Left just will not show the asterisk no matter what. My balance is good but I want to have access to the adjustment if I need it. Never had any of these issues with other radios. Seems crappy for a "High End" Transmitter.
Old 07-24-2006, 09:19 PM   #10
Still Bill's Avatar
Trust RC Old Man and HarshGuy. They know these things.
See Page 56 of your manual.
Old 07-25-2006, 05:03 AM   #11
Actully it is the most adustable radio on the market. Basicly the the VR is like Calabrating the Radio. All other radios must be sent back to the manufacture to do this. I usally do the VR adjustment about 1 time a month. READ YOUR MANUAL!
Old 07-25-2006, 07:23 AM   #12
HarshGuy's Avatar
Yes I do ...it's a most versatile word
Old 07-25-2006, 09:09 PM   #13
Glowster21's Avatar
Oh the MANUAL....That must be that thick glossy pretty looking book type thing I tossed off the the side when I opened the box. Thanks for the advice guys. I'll give it a try.
Old 07-25-2006, 11:21 PM   #14
Still Bill's Avatar
RC,
Your VR comments really picked my brain.
Do you record all your current settings before doing the VR recalibration?
Does the VR calibration apply separately to each individual vehicle setup? Seems like it must.
Thanks.
Old 07-26-2006, 05:02 AM   #15
RC,
Thanks.
I have not had to reset any settings after doing the VR adjustment.
The VR applys to the entire radio not just one model.
Hope this helps.
Need KO ex-10 Helios or JR Z-1! MrLesac R/C Items: Wanted to Buy 4 10-13-2007 03:38 PM
Braking Problem (Twister2 and Helios) acutts Electric On-Road 10 05-31-2005 11:56 AM
ko helios problem sedanaddict Nitro On-Road 6 04-11-2005 06:39 PM
KO Helios and personal transponder problem? J.Gonzalez Electric On-Road 13 03-05-2004 06:39 AM
