Old 01-21-2003, 07:28 PM   #1
Default TC3 factory team kit
If you buy a TC3 factory team kit are there any other hopups to buy? are there any other hopups you NEED to buy?
rcracer123 is offline   Reply With Quote
Old 01-21-2003, 07:44 PM   #2
there really isnt anything that you would desperatly need but some things that i would recommend are: brp or rpms wide front bumper, steering rack bearings and if your running stock class pick up some associated composite bones for 10.00 for a set of 4 to replace the aluminum ones, these are just unneeded rotating weight, the composites hold up fine in stock.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 01-21-2003, 08:00 PM   #3
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
IRS Aluminum input Shafts. They might need some light sanding to install the bearings.
John Stranahan is offline   Reply With Quote
Old 01-21-2003, 08:10 PM   #4
i wouldnt consider them a neccesity but they are definately worth the money. very light
[email protected]
Old 01-22-2003, 10:05 AM   #5
Here's what we've done to ours in the past 2 years:
Essential:
- Right away replaced the kit wheel nuts with Trinity blue aluminum ones. They hold better. IRS also makes these.
- Replaced the kit ball cups with stronger RPM cups. Kit ones will pop off in a crash.
- If your kit didn't come with these, get the new AE polished hinge pins. The original stock black steel ones are no good.
- Wide front bumper if you're not a good driver. It will save your front arms.
Not essential but helpful:
- Trinity blue foam bumper. Lighter, holds up better and it's blue!
- Trinity shock bushings. Holds the shocks on better using a nylon bushing inside the top mounting hole.
- Replaced the aluminum battery strap with composite one (also comes in graphite). Conforms to battery packs better and if you hard wire your batteries, helps avoid shorts from the strap being close to the soldering tabs.
- Recently replaced the aluminum bones with composite ones. Got tired of buying new ones to replace bent ones.
- IRS input shafts
- GPM blue aluminum servo mounts.
coolrcdad is offline   Reply With Quote
Old 01-23-2003, 08:08 AM   #6
Do you think the factory team is worth the extra 80 $ plus tires and rims over the team version for around 210? Im looking at the website and its looks like the team is the best bargain for 210, im planning on getting the duratrax streak 12 turn ESC and getting a 12 turn motor for it.
Has anyone clocked their car with AROUND a 12 turn motor?
Old 01-23-2003, 08:43 AM   #7
rcracer123,
Depending whether you will be racing and what type. The kit tires are fine for outdoors but not the best for carpet. If you think you will be buying the upgrades in the FT version, you will save money now by buying the FT versus the Team.
I work with new racers at our club, which is a carpet track. If you plan to race and haven't done it before, I would recommend against buying a modified motor first. I don't know what your skill level is or your racing experience/background. I always recommend to new racers that they start with a stock motor.
If you're set on a 12t, then I also recommend buying a Novak or LRP speed control versus the Duratrax. These are higher quality for not much more money.
Tell me more about what you plan to do withe car (race, bash, etc.)
Old 01-23-2003, 09:11 AM   #8
i plan on racing and and am going to buy a stock and a modified motor and have experience in racing rc cars, but i want something thats quick so thats why i wanted the 12 turn, i will probably get a 27 p2k stock to race in stock and bash with my 12 until i get better at it, then race my 12 turn.
***Factory Sealed 12L4 Factory Team kit*** EZRC R/C Items: For Sale/Trade 0 11-05-2006 06:53 PM
FS: Factory Team NTC3 with Sirio Evo 2 World Champ Engine, K Factory, MX3-S Radio.. R3VoLuTiOn R/C Items: For Sale/Trade 11 09-23-2006 08:37 AM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Trading Factory Team B4 for Factory Team T4 jamescam R/C Items: For Sale/Trade 2 08-14-2005 09:35 AM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
