Old 07-24-2006, 05:59 PM   #16
Charlie's Avatar
On average, the 3.5 needs to be down 1-3 teeth from the 4.5 under the same conditions.
Get your dremel out, time to open up them motor slots...
[email protected]
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 07-24-2006, 06:12 PM   #17
AngryAsian's Avatar
Oh damn... you're kidding Charlie.. don't be saying things like that.
Marcos. - got any idea what the smallest pin size that is compatible with the 110 is? My car is packed away at the moment without easy access. After i broke the topdeck, i'm still waiting for parts. I'm having bathroom work done so half my place is sealed up!
AngryAsian is offline   Reply With Quote
Old 07-24-2006, 07:13 PM   #18
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
[email protected]
I already done that!!! I can run up to 11.65 FDR on the Cyclone with the 110 spur
Old 07-24-2006, 07:13 PM   #19
Super Moderator
Marcos.J's Avatar
23 pinion
Old 07-24-2006, 07:44 PM   #20
Dremel?!
I think I can still fit a larger spur on the 415...I'm running a 106/26 on my 415 now with the 4.5R...
Ben.C is offline   Reply With Quote
Old 07-24-2006, 07:49 PM   #21
rayhuang's Avatar
[email protected]
NAH-Just put a bigger spur gear on and let it hang below the chassis!!!
Old 07-24-2006, 08:52 PM   #22
And crash the spur upon bottoming out...
Anyway,I'm with you...Just a bigger sppur will do...
Old 07-24-2006, 10:12 PM   #23
Super Moderator
Marcos.J's Avatar
Im working on a different layshaft pulley from 16 to 15 to change the transmision ratio from 2.4375 to a 2.6 and also to a 2.7857 ,Im just waiting for my belts to be made (front and rear) and that should solve the problem for the 3.5 or even the 2.5
Old 07-25-2006, 03:29 AM   #24
AngryAsian's Avatar
Sounds like hard work... where are you sourcing the parts?!
or are you machining them yourself? and the belts?
Old 07-25-2006, 05:21 AM   #25
Nicadrauspro4's Avatar
Originally Posted by RcCzarOfOld
Nicadraus,
I would have to say that, judging by the speed of the 4.5, the 3.5 is going to be the equivalent of a HOT 6x1. I honestly can't see any use for it in TC unless it's a friggin huge outdoor track. I think the peeps that are going to get the most use out of it are the 4 cell oval guys...
Tony
Thanks for the reply. Anyway, that would be freakin fast when used on TC.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-25-2006, 06:36 AM   #26
Super Moderator
Marcos.J's Avatar
pulleys I got are from different cars to try out, belts are been made by Gates belt , if the prototype works I may come up with a conversion kit.
Old 07-25-2006, 11:46 AM   #27
Super Moderator
Marcos.J's Avatar
also you can do it the getto way and raise the layshaft with a piece of lexan under the layshaft bearing and then place a shim under the top brace to hold the layshaft in.that should give you enough clearance to run a bigger spur 110 or 112
Old 07-25-2006, 03:49 PM   #28
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've seen Steve running this for some time at SoCal. It's fast. I'd say a very fast 7x1. Very quick out of the corners and very fast on the straight. And quiet too compared to most brushed motors.
Jon Kerr is offline   Reply With Quote
Old 07-27-2006, 11:48 AM   #29
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www2.towerhobbies.com/cgi-bin...?&I=LXNLY4&P=7
syndr0me is offline   Reply With Quote
Old 07-27-2006, 12:10 PM   #30
syndr0me's Avatar
Will the new sintered rotor work in the 4300 (w/upgraded endbell) and 13.5?
For sale LRP Sphere comp ESC Plus Vector X11 7.5 turn and Novak Velocity 5.5 as new D4 Australia For Sale/Trade 8 07-26-2008 01:25 AM
For Sale Novak Velocity rotors for Novak Brushless motors!! Marcos.J R/C Items: For Sale/Trade 61 01-30-2007 10:57 AM
Novak Velocity 4.5R Brushless Motor - NEW!! ycode65 R/C Items: For Sale/Trade 0 06-25-2006 12:21 PM
Novak Velocity Brushless Timox Electric On-Road 22 12-03-2005 04:14 PM
Novak GTB with 5.5 Velocity brushless olhipster1 R/C Items: For Sale/Trade 3 11-20-2005 09:19 PM
