Old 07-25-2006, 07:47 AM   #16
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
As long as you stick to a decent brand (energizer etc) id just use the energizer chargers. They take for ages, but if you have the time, its a much better way. plus they seem to charge the cells individually too. when on the go, i set my Integy charger to 8 cells, set the rest of the parameters, 1 amp, but cant remember what mv cutoff. My Helios uses a tonne of battery. Ive been pleased with it tho, racing up to 4 classes in the one day with it, i can easily last a day, and have gone 2 days straight before charging. I always have a backup set of batts ready to go anyhow.
also check out the amp number off a std charger like the energizer. from memory, they charge at like 130Ma so keeping around there is a good idea.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 07-25-2006, 10:29 AM   #17
Ducati-Rider's Avatar
Unhappy Polarity - Be careful - they all ain't the same!
Be careful moving chargers between manufacturer's transmitters. I believe Aitronics and Futaba are center positive while JR is reversed. You can screw up your battery packs by reverse-charging
And if you can - remove the cells/pack from the transmitter - if a battery vents, it blows all over your equipment and is a nasty mess of glop.
Ask me how I know
Ducati-Rider is offline   Reply With Quote
Old 07-25-2006, 11:29 AM   #18
axle182's Avatar
Post pics! lol Yeah thats why i either charge in the little energizer etc chargers (some are 2 at a time or 4 at a time) or i connect to the 8 bulk pack with my integy, but out of the radio. not worth throwing away a $400 radio over $20 worth of batts...
Aaron "AJ" Freind
Old 07-29-2006, 05:40 AM   #19
tried 500mah and worked a treat just took 3 hours
lol oh well thats life
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Charging AA rechargables for transmitter sloopy Rookie Zone 10 10-06-2007 07:53 AM
Charging transmitter packs - cutoff? AngryAsian Electric On-Road 4 06-02-2006 06:25 PM
fast charging transmitter pack whilst still in transmitter Xrayskid Electric On-Road 2 02-06-2006 04:16 PM
cdc charger - charging transmitter batteries - help! mrgsr Electric On-Road 4 02-09-2005 09:12 AM
Charging a Transmitter LEM Rookie Zone 3 05-05-2003 05:18 PM
