Old 07-17-2006, 05:30 PM   #1
Best gearing for Komodo Dragon 19T spec Pro motor?
Hi everyone,
I'm new to the RCTech forums.
Right now, I'm running a Tamiya 415 MSX with a Komodo Dragon Pro Spec 19T motor. Anyone know what a good pinion gear size to run for this setup? I'm running a 102T spur gear. I did a little research online, and I'm thinking somewhere around a 32-33 pinion gear would be a good size for race application? Not sure what final drive ratio should be for this Trinity motor. Any help is appreciated! Thanks!
Porkibear is offline   Reply With Quote
Old 07-17-2006, 05:54 PM   #2
tbeardmore's Avatar
The best way to gear is on the track. Listen to the car rev up to top speed on the longest straitaway just before you turn into the corner.
Use a temp gun and check that it's not getting too hot. About 170 degrees is about the max I run mine.
Hope that helps!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 07-17-2006, 06:45 PM   #3
PitCrew's Avatar
Depends on the size of the track.
Start with a relatively small pinion and go up untill your lap times start to fall back off just a bit, then go back down one tooth.
PitCrew is offline   Reply With Quote
Old 07-17-2006, 07:11 PM   #4
Glowster21's Avatar
Trader Rating: 116 (100%+)
Running a Komodo on foams we have been in the neighborhood of 26.5mm rollout.
Glowster21 is offline   Reply With Quote
Old 07-17-2006, 08:56 PM   #5
Trader Rating: 38 (100%+)
Wow our local fast guys run at 1.4+ rollout (35mm). When I tried 1.3 my motor came off the track at 250+ degrees. Not sure how they do it. They say they arent doing anything different then me. I try to gear down and cant keep up! Dont like having to cut the comm and replace the brushes every heat.
or8ital is offline   Reply With Quote
Old 07-17-2006, 11:02 PM   #6
ottoman's Avatar
R/C Tech Charter Subscriber
TQed the Sizzler Sunday at Trackside (carpet foams) with a 1.18 rollout
ottoman is offline   Reply With Quote
Old 07-18-2006, 04:30 AM   #7
Glowster21's Avatar
Wow...Any Komodo I've seen rolled out over 28mm or 1.10 has smoked.
Old 07-18-2006, 05:35 AM   #8
What size track and layout are you running the 28mm on? We where running a 35mm for a 60 x 110 asphalt track. The layout was tight with a long straight and long sweeping turn.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-18-2006, 06:01 AM   #9
The track I run at as well is similar size (not very technical though) and the top guys also run 35mm. What do you do to keep your motors cool? I have a fan on my endbell but that is about it. When I come off the track geared that high the motor is 250 degrees, the comm is black and the brushes are burned up. It also starts to fade the last 30 seconds.
Old 07-18-2006, 06:15 AM   #10
Glowster21's Avatar
We run a 60x90 technical track with a long straight and 2 high speed sweepers. The really fast guys are turning consistent 10.4 - 10.5 second laps. One of the motors that literally dripped epoxy after a run was frozen with a Crazy Ronnie Motor Freezer before the run, had the Double Cool Can Fan in an RDX, and was rolled out at 29mm. When I rolled out at 30mm on my RDX the motor dropped off so hard with 30 seconds left I thought I was running a silver can 540. 26.5mm has been the optimum so far for those of us that have been testing them on that particular track.
Old 07-18-2006, 06:20 AM   #11
Like Ottoman at the sizzler I was running a 1.14-1.15 should have gone up more, motor came off hot, but the brushes were no where near burnt up.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 07-18-2006, 06:22 AM   #12
I run a 3racing fan on my motors. The motor comes off at around 190 degrees. The com is discolored. We can get 2 runs out of the com and brushes. Our Team motor builder uses his speed brushes. He will not tell us what the brushes are. When I geared down the motor would over heat and turn the com purple and the brush tips where silver. The motor would stop running after 3 minutes. I will only use the KD19 for big races. The Atlas and C2 aren't as hard on brushes.
Steve Walter
Old 07-18-2006, 06:25 AM   #13
Trader Rating: 198 (100%+)
I have heard the XXX brush holds up much better on the KD. I am waiting on mine to try it myself.
The KD is so darn tuff to gear. The first time out with one I burnt it up I did not feel it was over geared or under geared. It was fast thought
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 07-18-2006, 07:10 AM   #14
dawgmeat's Avatar
I race at the local track with Glowster the KD are fast but I would not use for club racing at all becuase of the money it you have to put into maintain it high level i.e. brushes for every run and the constant cutting of the comm =practice, 3 qualifiers and a main your comm will be toast in 3 race days and the high temp has killed the magnets but anyway I'm runnin' foam at 27mm rollout purple springs +/- XXX brushes good hunting
dawgmeat is offline   Reply With Quote
Old 07-18-2006, 07:34 AM   #15
Since you all seem very knowledgeable on motors I'll hijack this thread a bit and ask about gearing for the Checkpoint Money 19T. Guys at my track are running 1.3 (33mm) rollout on them and I also cant keep the temp down. The brushes dont seem to burn up (turn purplish but still work) and the comm doesnt get as bad as the KD. The motor does come off 240 degrees though.
trinity komodo dragon motor installation help irieriddim Electric On-Road 4 05-15-2010 06:49 PM
Komodo Dragon Mans343 Electric On-Road 133 02-22-2010 12:42 PM
Komodo Dragon II 19t wolfden R/C Items: For Sale/Trade 0 01-19-2008 09:02 PM
What FDR for a Komodo Dragon 19T? martman_oc Electric On-Road 3 12-07-2007 03:56 PM
Komodo Dragon Johnny Wishbone Electric On-Road 13 06-06-2006 12:54 AM
