Old 01-20-2003, 10:34 AM   #1
Default Original HPI RS4 set up help
I'm helping a new young racer at our track with his HPI RS4, a gift from another driver. It's the original chassis, like the Rally, but with ball diffs and graphite decks. I'm looking for carpet set up tips, especially shock oil, springs and mounting position. He has a used set of good tires and a pair each of green and blue springs. So far the car traction rolls like crazy.
Thanks for any help.
coolrcdad is offline   Reply With Quote
Old 01-20-2003, 10:59 AM   #2
popsracer's Avatar
coolrcdad;
Traction rooling is usually caused by 2 things. TOO high of a ride height and TOO soft of springs.
Lower the ride height to between 4mm & 5mm first then try some stiffer springs at both ends of the car.
You can also install some limiter spacers on the outside of the shock shafts, but I would try the other two things first.
popsracer is offline   Reply With Quote
Old 01-20-2003, 01:37 PM   #3
R/C Tech Founder
R/C Tech Charter Subscriber
If I remember correctly, the original RS4 is not the full 190mm wide, either. That will make it roll much more often.
You could take some of those spacers that come with HPI wheels and use them in the wheel hex areas to offset the wheels by a couple of milimeters on each side. That might help a bit.
Also, it is often easier for a new racer if you take some of the steering out of his radio and maybe even change the throttle exponential until he gets a feel for the track and how the car handles. Then, gradually add it back in as he becomes more accustomed to it.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-20-2003, 02:32 PM   #4
Cole Trickle's Avatar
If the car got droop screws, those will effectively stop traction roll, by limiting the the downtravel.
I cant recall the complete Dr. Diff starting setup for carpet, but I do remember this: HPI White and Yellow progressive springs (yellow up front) and 60 wt oil on all four shocks. Piston nr. 3.
There are several blue and green springs, so it's a little hard to guide. However, they got different length, so if you go to www.hpiracing.com -> option parts -> spring chart, you should be able to identify them. If the current ones are close to the progressives I mentioned, then you probably should get some stiffer ones.
By the way, it's a good car.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-22-2003, 10:11 AM   #5
Thanks for the help. Good suggestions. I will try them.
Old 01-22-2003, 04:52 PM   #6
Tom
Tom's Avatar
i still run a rs4
track is out netball courts high grip very fast and open with some hair pins
setup
shocks
40wt all round
#4 pistons
hardest springs u can find
front
8 deg caster
1deg camber
0 toe
top arm in lower position
0 kick-up
ride hight 5mm
midle shock mount on arm
rear
camber 1 deg
1 toe in
outer shock mount on arm
inner on tower
arm in the outa most hole on the hub
tires ellegi 40f fronts and 37r rears(there foams)
for carpet try 50wt shock oil
Tom is offline   Reply With Quote
Old 01-23-2003, 04:10 PM   #7
Default gearing help
I need suggested gearing for the RS4 Pro using 48 pitch gears for a GM3 motor. Will probably use a 96t spur. Thanks!
Old 01-23-2003, 09:02 PM   #8
Tom
Tom's Avatar
i run an orion core with 32.5mm roll-out
i think thats to much for the gm3
start at say 27mm roll out and work ur way up in 1mm levels
make sure you can hear the motor reving out before going up
Old 01-24-2003, 05:34 AM   #9
Default Re: gearing help
This depends a lot on the track.
A rule of thumb, are that the should reach top-end at 3/4 of the longest straight.
If the motor gets too hot, you should gear a little lower. It's good, if you're able to keep your fingers on the motor for at least 10 seconds.
As far as I know, the GM should be geared 2-3 teeth (pinon) lower than a P2K (talking same car, track etc.)
Old 01-24-2003, 07:14 AM   #10
Thanks. I finally figured out the what the kit 64p ratio is and I'm transferring that to 48, with lower gearing the GM3. The kit is 122/35 in 64p, which comes to about 96/28 in 48p.
ORIGINAL RC10T AND ORIGINAL RC10 BUGGY MIKE_IN_AZ R/C Items: For Sale/Trade 1 08-07-2008 07:56 PM
SP vs Original TeckLancer Electric Off-Road 3 06-10-2008 06:06 AM
Original MR-4TC same as New MR-4TC BD? alexpascual Electric On-Road 4 05-26-2005 04:03 PM
KO EX1 - Original Bwadd2002 R/C Items: For Sale/Trade 0 12-11-2003 04:14 PM
