Old 07-14-2006, 10:28 PM   #1
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
Default Soldering iron? Butane/electric?
i think this is the best place to post this cause every1 is always soldering up their battery packs..
umm i was wondering wat is better? a butane or a electric soldering iron??
im guessing it wouldnt be safe using a butane 1 at nitro events but in electric it should be ok?
i wana know because a good 100w soldering iron is the same price as a butane soldering iron..
thanks..
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 07-15-2006, 12:33 AM   #2
buzz06's Avatar
Send a message via MSN to buzz06
I would recomend eletric cos if ur using the butane one and it run's out you dont normaly have a spare with u, and I dont think u would be able to buy one from the race event ur at!
buzz06 is offline   Reply With Quote
Old 07-15-2006, 12:44 AM   #3
Drewdc90's Avatar
Normally if you use a butane one you would have a can of LPG to fill it up when it runs out. I haven't use an electric one enough to say which I prefer but the gas ones seem to heat up alot quicker.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 07-15-2006, 12:51 AM   #4
Got Xray?'s Avatar
Send a message via MSN to Got Xray?
I rather my weller portasol over my electric iron,just because its SO easy to work with,no big wire.
It heaps up super quick and is rated at 70w on its highest setting.
!xray!
Got Xray? is offline   Reply With Quote
Old 07-15-2006, 03:54 AM   #5
the 1 im getting has another tube that u click in....i want it for the quick heating and i can just turn it off wen not in use and heat it up quicker aswell as i can use it for heatshrinking and stuff.....
aswell as a spare can of butane gas in my pitbox....
HIP Baja 5sct
Old 07-15-2006, 10:36 AM   #6
buzz06's Avatar
ok, never used a butane one like, but I have considered getting one, might get one now
Old 07-15-2006, 10:47 AM   #7
Registered User
Scuad X's Avatar
Majority uses electric irons. I use electric with a ceramic tip and what I like the most is that the solder doesn't eat up the tip.
Scuad X is offline   Reply With Quote
Old 07-15-2006, 10:56 AM   #8
X2
X2's Avatar
After switching to a gas iron I can say I prefer it in every single way.
It heats up much quicker, its easier to use with no wires hanging around, its usually lighter and the gas lasts a long time.
X2 is offline   Reply With Quote
Old 07-15-2006, 06:41 PM   #9
hey guys ne1 got a PRO-70 Butane soldering iron?
heres a link PRO-70 Butane Soldering Iron....click ere
46.99....and im gona get a thicker tip....and some gas....around 56 bucks all up
it goes from 25 to 80 watts....upto 450* degree celsius....is that good?
and if ne1 has 1 wat tip do u need to make it into a torch...for like heatshrink n stuff??
and wats a good tip for soldering battery packs? 5mm?
HIP Baja 5sct
Old 07-15-2006, 09:33 PM   #10
cyber3d's Avatar
Hi, newbe here.
What about those "cold heat" soldering device? Anyone use them?
Victor
cyber3d is offline   Reply With Quote
Old 07-15-2006, 09:55 PM   #11
well guys i bought a IRODA SOLDERPRO 50K....60 bucks from dicksmitch electronics
30 to 70 watt range,480*C degrees celcius MAX
its includes a hotknife tip,soldering tip,hot blower and a blowtorch reaching temps to a MASSIVE 1300*C !!!!
run off butane and has approx 30 min run time,very compact and heats up in around 5 secs,easy to use and includes solder aswell aswell as a box with foam padding
now i think ppl use a sort of "hammer" bit for soldering packs?....should i buy one of those?
im not a hardcore racer.. i just buy individual cells every now n then and solder em up....much cheaper than an already built pack
HIP Baja 5sct
NIP OFNA Cordless Butane Multi-Function Soldering Iron $35.00 Shipped xsxracing R/C Items: For Sale/Trade 7 08-11-2008 08:40 PM
Anyone Use a Butane Soldering Iron? SlamMan Electric On-Road 14 12-06-2006 06:48 PM
Soldering Iron Fix! andrewdoherty Electric On-Road 21 07-12-2006 09:30 PM
soldering iron. oakesy2001uk Electric On-Road 2 02-15-2006 04:54 PM
soldering iron rc_square24 Electric On-Road 6 06-18-2004 06:11 PM
