Old 01-19-2003, 10:40 AM   #1
Default Trinity Monster Horsepower stock motor
What's been your experience with this motor? Is it faster than anything else out there in stock? How do you tune it? Thanks for any info.
coolrcdad is offline   Reply With Quote
Old 01-19-2003, 12:59 PM   #2
popsracer's Avatar
Default Monster Stock
coolrcdad;
My experience has been good. The MS is a VERY high RPM Motor and performs best when geared as such.
You will want to gear about 3 teeth smaller on the pinion when compared to a P2K to start.
popsracer is offline   Reply With Quote
Old 01-19-2003, 01:32 PM   #3
fasterdanu's Avatar
i wouldn't reccomend them guy's keep frying them all the time same with green machines i think you would be sorry for buying one.
fasterdanu is offline   Reply With Quote
Old 01-19-2003, 02:07 PM   #4
popsracer's Avatar
Default guy's keep frying them all the time
fasterdanu;
I truely believe that most people are over gearing their MS's. What I have found is that instead of "gear-up" try gearing down until the car slows down. The exact opposite of what one would normally do, but it seems to work with these motors.
Old 01-19-2003, 02:52 PM   #5
I've never fried a GM3. I know you need to gear the Monsters way down. Reason I posted this thread is to get additional feedback to what I saw at my club yesterday: winning stock and 12th scale stock racers used this motor. I've already invested a lot in Fantom stocks (P2K2 and GM3). Has Trinity upped the bar?
Old 01-19-2003, 05:19 PM   #6
Neil Rabara's Avatar
Trinity in a sense has upped the ante. The MS needs to be geared down similar to the GM3, but lower. You are looking between a 7.2 to 7.8 final drive ratio on a touring car, not sure on a 1/12th scale or offroad.
Neil Rabara is offline   Reply With Quote
Old 01-19-2003, 06:18 PM   #7
Super Moderator
Grizzbob's Avatar
Absolutely right, I've NEVER burned up a GM3 or Monster because I make sure I NEVER overgear it. There's no point in gearing one as high as you would a P2K 2 or P2K(or MVP) when they don't make good torque at low rpm & few people have the batteries to push one with that gearing(that's why the factory guys can get away with it, their batteries have more voltage & lower resistance than most any of us have access to, so they can still get good acceleration form such a tall gearing, & of course they couldn't care less if a motor burns up when their motor guy has 10 more waiting at the ready. Not that I'm complaining, it's just that we mortals simply can't do things exactly the same as they do). As for gearing my Monsters, I've had some good luck gearing mine at around 7.5-8.0 final drive in my TC3, depending on which one I'm using(some have less top end but a bit more torque so I can gear up a bit), & this is on both a medium sized & fairly big track(the big one being S&N's Trackside in Milwaukee). Just take care of it & I think you'll be pretty happy with them...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-19-2003, 07:39 PM   #8
Send a message via Yahoo to Doug Gaut
Well said Grizzbob. Its hard to believe but I keep finding myself gearing the monster about the same as I do my 11 and 12 turn mods in my XXX-S! The motor loves low gearing as well as lighter tension springs compared to what I used to run on my P2Ks.
Doug Gaut is offline   Reply With Quote
Old 01-19-2003, 08:46 PM   #9
Thanks guys. We run a TC3 so the drive ratio suggestions are great.
I see that Putnam Propulsion is tuning a version of the Monster (RC4Less sells them). I wonder if Fantom will follow.
Old 01-19-2003, 09:23 PM   #10
Fantom has theirs out also.
Old 01-20-2003, 08:46 AM   #11
Doug,
Where did you see it? I can't it on Fantom's website. Thanks.
Old 01-20-2003, 05:10 PM   #12
Exclamation MONSTER Horsepower Stocks
hey guys ... I am kinda new to this sport ... ( in it about a year now ) but I love these new trinity motors. heres what I have ...
MHS pro p/n RC2141 .... heres the rundown on the label ....
21358 rpm @ 5.0v
66w @ 10.4 k rpm
49% @ 14.8 k rpm
99.1 nmm
now I may have gotten a freakinstein motor but the torque and power draw are very close to three of the four GM3's that I own with the efficiency being a little better and the rpm's being just out of the ball park better .... for example
GM3 pro p/n RC9427
19788 rpm @ 5.0v
64w @ 10.4 k rpm
48% @ 13.8 k rpm
100.5 nmm
now ... the GM3 listed above has only two skims on the comm and new serrations on the stock brushes. the MHS was box stock. both were broken in for 600 secs at 2.0v on a turbo 35 ( per the instructions of a fast guy at our track ) ... the GM3 in practice geared 37/96 ( 64 pitch ) was about average. it kept up with the packs of stock racers when my driving skills allowed ..... now the MHS geared the same was just a touch slower than some guys running chamelon 2 motors ( 19 turn ) . the fast guys at the track told me when changing motor styles within a brand look at the torque the motor produces and gear up or down depending on that for the new motor .... my MHS comes off after a race ( 5 min ) just slightly warmer than my GM3's but not burning hot or hot enough to blue the comm or the brushes ...
this motor with my bad driving moved me from middle of the C main to lower-middle of the B main and I was able to gain spots in the B because of the speed to make up for my driving problems.
I love this Freakinstein motor Trinity made.
roddude65 is offline   Reply With Quote
Old 01-20-2003, 06:38 PM   #13
Coolrcdad, I have seen several on Ebay and they are posted on the shopatron site also.
http://www.shopatron.com/select_site.phtml
Old 01-20-2003, 06:47 PM   #14
Aluma's Avatar
gee, i'm running a 6.3 ratio on the monster and It dont even get hot. Did i get some freaky motor or sumtin?
or am i calculating wrong....
61 spur, 25 pinion (48pitch metric) with an internal 2.6 = 6.34
Aluma is offline   Reply With Quote
Old 01-20-2003, 09:36 PM   #15
skibum989's Avatar
There's gotta be something up with that motor, or you run on a very big track and you have the throttle control of Masami...... My guess is the former not the latter...
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Trinity Monster Horsepower Motor Machine FTTim R/C Items: For Sale/Trade 0 10-25-2005 10:02 AM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 3 08-10-2004 12:44 PM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 0 08-09-2004 11:07 PM
Monster Horsepower Stock motor ROCKS!! big al Electric On-Road 62 05-04-2003 01:54 PM
