Old 01-24-2003, 12:54 AM   #31
I'm gearing my 8 double at 7.5 and my 9 double at 6.9. Both higher than u guys gear your stockers
ixlr8nz is offline   Reply With Quote
Old 01-24-2003, 08:55 AM   #32
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Cool Similar gearing..
Hey Hey..
That's the type of gearing that I might use at Yatabe Arena but I usually limmit it to 7.8.
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-24-2003, 10:33 AM   #33
popsracer's Avatar
Default Trinity Monster Horsepower stock motor
These Motors can make over 30,000 RPM at 7.2+ volts. What kind of RPM will a 12T make?
I think that these are better all around motors than the GM3's. They have a little more RPM, a least the same average power, and can take the over-gearing a little better without smoking. (from my experience).
To be on the safe side, start with a FDR in any T/C of around 7.5-8.0 and gear up or down depending on what the motor is telling you. Right now I'm at 7.67 in my Pro-3 and no one is pulling me on the straight but I could use a little more punch, so I'm going to try 7.9 and see if the car slows down on the straight.
popsracer is offline   Reply With Quote
Old 01-24-2003, 10:58 PM   #34
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I'm running a 7.3 in my Losi for foam (tight track). No one but mod cars pass me on the straight and i have plenty of infield rip. For rubber go 0.5-0.7 higher than that on a tight track.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-25-2003, 02:43 AM   #35
Am TQ so far at the New Zealand On Road R/C Champs with one round of qualifying to go, using a Monster Stock. My car was probably the fastest car on the track using 5.75 gearing and no changes to the motor. The car is on the verge of dumping with 3000hv's!
Old 01-25-2003, 09:53 AM   #36
STLNLST's Avatar
Trader Rating: 21 (100%+)
what do you mean by higher as I have found that people have different meanings. I call higher gearing going lower on the final drive ratio so for your example of 7.3 going higher to me would be anything 7.2 or lower. Anything 7.4 or higher I'd assume that someone is gearing down for more punch. Is this your way of thinking too? Next week will be the first time out with this motor on carpet with rubber tire's and I want to make sure that I'm gearing it correctly. I use to run the GM3 at 6.89 on ashalt but I haven't run stock on carpet in two years. Thanks in advance for any suggestions you can give.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-25-2003, 04:39 PM   #37
ottoman's Avatar
STLNLST... I just ran the Novak race (rubber on carpet) everyone in the expert A main (with a monster) was running between 7.5 and 7.8 for a final, or at least thats what they said I ran 7.69 and 7.83 all weekend and went with the 7.83 for the A.
ottoman is offline   Reply With Quote
Old 01-25-2003, 06:23 PM   #38
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
otto - some of the factory guys were at 7.3
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-25-2003, 06:29 PM   #39
ottoman's Avatar
lol... thats why I said "expert stock" maybe if I had the voltage and corner speed they had I could run that gear too!!!
Old 01-25-2003, 08:46 PM   #40
STLNLST's Avatar
ottoman- Thanks for the info. I'll keep you up to date with how it works for me. I won't get to run it until next weekend though.
Old 01-26-2003, 01:56 PM   #41
Just got my Monster pro version. Has anyone tried different springs or brushes on these and has it helped? I usually run Fantom 315s on my stock motors. This motor will go into my 12th scale, where I had run green springs on both sides of a GM3.
coolrcdad is offline   Reply With Quote
Old 01-26-2003, 05:55 PM   #42
Super Moderator
Grizzbob's Avatar
Really, I've been pretty happy with those brushes & the red/green spring combo, the motor's efficient enough to make time(especially with 3300's in the car, so max power is now more important), but I've also tried one with all red & all purple(not sure yet if it works well, though, it's not a big difference on my dyno or in my touring car). And about guys running the Monster at the Novak race, I also ran there & I also used final drive ratios between 7.57 & 7.81 with good results(I was fast enough to make the Stock A, but I just made a couple too many driving mistakes in qualifying so I missed it by about 2 or 3 seconds)...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 01-26-2003, 06:05 PM   #43
Send a message via AIM to ZER01
I ran a monster this weekend from lightspeed products and it was too good to be true for a very tight track. The overall was 8.28 with 2.370" foams and skimming the comm every 3 runs. EPIC purples on both +/-(I beleive this is where the torque came from) with 3910 lightspeed brushes. Awesome stock motor.
ZER01 is offline   Reply With Quote
Old 01-26-2003, 09:09 PM   #44
Send a message via AIM to RideRed98
i too ran at the Novak race...made the A main in Stock Sedan(9th) but was on TQ run till i tried passing a slow guy...hehe...i was geared at between a 7.5 and a 7.8 as well in the Losi XXXS GP...
RideRed98 is offline   Reply With Quote
Old 01-26-2003, 09:39 PM   #45
DavidAlford's Avatar
Send a message via AIM to DavidAlford
I've played with springs and brushes, but I keep going back to the 4499, red/green setup. It seems to give the motor its best overall power. In a Losi I am gearing 32/128 and it hauls.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Trinity Monster Horsepower Motor Machine FTTim R/C Items: For Sale/Trade 0 10-25-2005 10:02 AM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 3 08-10-2004 12:44 PM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 0 08-09-2004 11:07 PM
Monster Horsepower Stock motor ROCKS!! big al Electric On-Road 62 05-04-2003 01:54 PM
