Old 01-20-2003, 09:40 PM   #16
Korey Harbke's Avatar
soem guy at rain city whooped all our butts with one of those. It pulled every car on the straight.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-20-2003, 09:46 PM   #17
skibum989's Avatar
Yeah, how did he get it to be so fast in a touring car? I gotta know Jose's secret.....
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 01-21-2003, 07:42 AM   #18
Sushi, skibum -- I saw that, too (my son is Sam Forbes, races 19t, 12 stock). Must have been the motor. Randy and Chris used them in their 12th scales last weekend.
coolrcdad is offline   Reply With Quote
Old 01-21-2003, 07:45 AM   #19
Doug -- Is it the "silver" motor Fantom has on shopatron? Thanks.
Old 01-21-2003, 08:16 AM   #20
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Can someone help a motor newbie out?
I have a P2K2 pro and currently I run the stock spur gear that came in the Losi XXX-S and run a 23 tooth pinion. If I get the Monster stock motor, what pinion should I run? Or should I change my spur as well?
Thanks!
Jits
JitsuGuy is offline   Reply With Quote
Old 01-21-2003, 08:43 AM   #21
Rob68's Avatar
or am i calculating wrong....
You need to include tire size as well. That will make a difference. If you run foam tires, you need to calculate roll out. Its more important then final drive, because its always changing as your tires get smaller.
Rob68 is offline   Reply With Quote
Old 01-21-2003, 09:27 AM   #22
Aluma's Avatar
well, i just run rubber tires....the diameter is 2.406 inches...i guess my rollout should be 1.191 ...but how does that figure into the real ratio?
Aluma is offline   Reply With Quote
Old 01-21-2003, 09:34 AM   #23
tufferwilde's Avatar
JitsuGuy -
Couple of questions for ya - what size track are you racing on? foams or rubbers?? If Foam - what diameter tire are you running
In general, I would drop 1-2 teeth running 48 pitch gears... when changing the spur - think of it this way, each spur change is roughly 1/2 tooth on a pinion... or 23/90 is roughly the same as 22/86....
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 01-21-2003, 10:36 AM   #24
popsracer's Avatar
Default Changes in gearing for the Monster Stock
Guys;
The general concenses is when going from a P2K to a Monster start with a 3 tooth pinion difference in the gearing. A good starting FDR for any TC will be in the 7.5 to 8.0 range for a medium size track with a straight 80 to 100 ft. Then adjust both the pinion and spur to get the optimum ratio.
These Motors like to rev and will respond to lower gearing (higher FDR). Also try a Red/Red spring combo. This will increase power in a TC with a very slight reduction in RPM (Dyno Tested).
popsracer is offline   Reply With Quote
Old 01-21-2003, 10:43 AM   #25
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Thanks!
Jits
At RCR I would run with a 22/90. I've found that to be a pretty good ratio for Randys, Enid and Comp.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 01-21-2003, 10:59 AM   #26
Aluma's Avatar
well, my straight is about 90ft longwith a 90 degree turn into a 50 ft straight. when i first got the Rev. of monster I did exactly what you guys are saying...go down 2 -3 teeth on the pinion. I ran it at 61/22...lets just say that it was rather pathetic, i was still doing okay, but it was cuz i wasnt crashing due to uncontrolable speed... :P so i kept going up on the pinions.... 23 was a bit better, 24 i could feel the motor barely strecthing its legs, 25 fast but feels like it can take way more. 26...dang, tamiya dont make it. and i'm looking for spurs that will fit my car, so far I've found a 72 tooth 48pitch robinson spur....but that dont fit cuz its too big by about a 1mm. ordered a 66 spur and hopefully that'll fit.
Old 01-21-2003, 04:59 PM   #27
JDM_DOHC_SiR's Avatar
Man when I hear all of you guys talking about gearing these 27T stocks up in the 7.5~8.2 range . I just find it hard to belive..I have 3 P2K2's and I usualy run them in the 5.6~6.1 range but I don't us them that often here in Japan .... but for the 23T JMRCA stock motors that I use I ususally end up gearing them in the 5.2~6.0 range and thats the norm for over here..It's just weird that you guys gear stuff way different than over here ..
BTW ..the local track that I run at only has a straight of about 12m and is very technical
Just my 2 Yen
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-21-2003, 08:31 PM   #28
popsracer's Avatar
Default Best said quote on the MS
Originally posted by Doug Gaut
Well said Grizzbob. Its hard to believe but I keep finding myself gearing the monster about the same as I do my 11 and 12 turn mods in my XXX-S! The motor loves low gearing as well as lighter tension springs compared to what I used to run on my P2Ks.
Guys;
this is the way these Motors like to be geared. Try it and you'll be susprised.
Old 01-23-2003, 08:55 PM   #29
Default Re: Best said quote on the MS
Originally posted by popsracer
Guys;
Ok ... so how do you gear an 11 or 12 turn mod ... I have only run mod for one pack on a practice night ... it was a burrowed motor I dont know the wind but it was geared as low as i had with the stock spur .... I currently gear my MHS in the 37/96 ( 64 pitch )range ... one lower or higher depending on the infield. tight and technical one or sometimes two lower ... open and fast one higher.
thanks
Roddude65
roddude65 is offline   Reply With Quote
Old 01-23-2003, 10:10 PM   #30
I think I've met you guys before. Yeah, Jose just pulled away as soon as I caught up in the infeild. On the straight I thought he had a 19T. lol
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Trinity Monster Horsepower Motor Machine FTTim R/C Items: For Sale/Trade 0 10-25-2005 10:02 AM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 3 08-10-2004 12:44 PM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 0 08-09-2004 11:07 PM
Monster Horsepower Stock motor ROCKS!! big al Electric On-Road 62 05-04-2003 01:54 PM
