Old 03-20-2003, 04:23 AM   #166
OleC's Avatar
Anyone have any suggestions for brushes on the Peak Hellfire?
-Oops! Probably wrong thread for this question, sorry.
OleC is offline   Reply With Quote
Old 03-21-2003, 02:48 PM   #167
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default gearing?
i have the monster pro runnin in my tc3 and i dont realy nw ne thing about gearing. how should i gear it? #spur/#pinion i dont knw ratios or ne thign so dont gimme one of those.
rdub202 is offline   Reply With Quote
Old 03-21-2003, 06:32 PM   #168
Johnny J's Avatar
It depends on what type track your runningon and if its long and fast or short and tight. On my windey (spelling?) type tracks i run with a 24t pinion and a 72t spur and it works well for me.
Johnny J is offline   Reply With Quote
Old 03-21-2003, 10:08 PM   #169
rdub202's Avatar
Default my track
my track is technical, lots of turns and crap but theres a decent straight on it. if that helps?
Old 03-21-2003, 10:25 PM   #170
Johnny J's Avatar
Sounds sort of like my track. Well i would try a 25t pinion with the stock 72t spur. I tried that today and liked the way it felt. If thats not right try going up or down a tooth. The lower the teeth on the pinion the more acceleration and more teeth is less accelertion but more top end. Hope that makes sense
Old 03-21-2003, 11:38 PM   #171
popsracer's Avatar
Default Dyno number with a Monster
Guys;
Anyone else have a Motor Dyno, and have you done some pulls with the Monsters?
I've got a Robitronic Dyno, and am not satisfied with the numbers I'm seeing with my Motors and the Track performance either.
I did gain slightly by using Putnam Brushes, but was hoping for a little more.
Also tested the 'Tribo Lube' Com drops and was very dissapointed in the Dyno tests. All of the numbers were down and this will definately show at the track.
popsracer is offline   Reply With Quote
Old 03-22-2003, 09:32 AM   #172
rdub202's Avatar
Default it did
thx johnny it did help im thinkini about goin to the track today but idk if i am gonna. if i do ill get new pinion and test it out.
Old 03-31-2003, 11:02 AM   #173
popsracer's Avatar
Default Trinity Monster Horsepower stock motor
I just wanted to say that the gains that I am seeing on my Dyno with the Putnam Brushes (Green + and Blue -) on a Monster Stock, really showed up at the track yesterday. The car was very fast, better than ever.
What was very dissapointing was running Putnams on my Matrix V10. That Motor just didn't like them.
Old 03-31-2003, 05:08 PM   #174
Send a message via AIM to SteveA
pop, what putman brushes are they that are working on the monster? do they make more power then the 767?
SteveA is offline   Reply With Quote
Old 03-31-2003, 09:22 PM   #175
big al's Avatar
I finally was able to use my MHS this weekend up at speedworld raceway in Roseville,ca. I was very pleased with this motor!! I tried the putnam combos ,but for some reason the RPM's just were'nt there. As soon as I put in 4499's,BAM!!! Rpm and a decent amp draw. I know,I know "amp draw doesn't tell you anything"....tell that to the rest of the sportsman stock guys there, I had MAD horsepower. Nice bottom end (as does my wife) and a real nice climb to max speed down the 110' straight-away. I had a little on power push that kept my laptimes around 17.5 sec,should be ready fot the speedworld cup this april 26-27!!
For all you Tc3 guys, I fist tried a 7.5 ratio--too low, then 7.29 (24/70)took TQ. Then 7.2 (25/72) for the main, beat my tq qualifing time by 1 second--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 03-31-2003, 09:27 PM   #176
deleted
Sydewynder is offline   Reply With Quote
Old 03-31-2003, 09:30 PM   #177
Pops
Are you using any comm drops with the Putnams? If so, which one.
Old 04-01-2003, 09:54 AM   #178
popsracer's Avatar
Default Com drops
Sydewynder;
I recently bought 'Tribo' drops and tried them on several Motors on my Robi Dyno. VERY dissapointing results. Overall power, torque down by 5+%. Clean the stuff out and everything is back to normal. With test results like that, I'm afraid to even try it on the track.
big al;
The Monster seem to like a 7.87 Ratio in my Pro-3 even on a slightly larger layout. Tried going up and down a few teeth on the spurs and both yield slower lap times. My Friend has an X-Ray and He's running 8.3 FDR with a Monster.
What ever works, go for it.
Old 04-01-2003, 10:30 AM   #179
big al's Avatar
Hey pops, Have you checked you're brush alignment? I've got about 1mm of blackening on the edge of the brush face. I think I can get rid of about 50% of that. In theory, the less brush blackening the stronger overall power. Just something I was wondering. 7.87..whoa that's low! About how technical/not technical is your track??--AL
Old 04-01-2003, 10:50 AM   #180
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Pops, if you try the Tribo on the track (which I recommend that you do) you will notice the difference. Tribo does not show up real good on the dyno because of its chemical properties. Don't be afraid to mess around with gearing as well when using the Tribo.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Trinity Monster Horsepower Motor Machine FTTim R/C Items: For Sale/Trade 0 10-25-2005 10:02 AM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 3 08-10-2004 12:44 PM
For Sale/Trade: Novak GT7 ESC, Trinity Monster Stock Horsepower Motor, Team Orion jferg10472 R/C Items: For Sale/Trade 0 08-09-2004 11:07 PM
Monster Horsepower Stock motor ROCKS!! big al Electric On-Road 62 05-04-2003 01:54 PM
