IFMAR AGM in Collegno - Future of ISTC
#331
The 12th scale racers are using 4 cells and are getting all their laps and no more radio problems then normal...I think?
One thing is for sure, some testing is in order, since speculation is useless, except for entertainment.
Side subject; I wouldn't blame the RS200 for spectator deaths in Rally, maybe standing next to the track is a factor? I wonder how many deaths there would be in US racing organizations if people could stand at the edge of the track during the races, regardless of the technology in the cars?
Kind of like saying meat grinders should be safer because people keep sticking their hands in them and having them mutalated due to their poor design.
LOL, Jim
LOL, Jim
#332
Also consider the future with technologies like this in your TC. http://forums.radiocontrolzone.com/s...d.php?t=222362
#333
Originally Posted by Smoking motor..
Reasons why Touring cars are faster.
1. Chassis design has enabled the the cars to be better balanced and thus have a much higher cornering speed.
2. Supension geometry has now come to an ideal geometry most TC supension has a very simlar pivot dimension and roll center adjustment range this make the car very easy to drive at speed so they don't handle like a shed.
3.Tyre technolgy allow the tyre to run hotter for longer and produce more grip than ever before more grip more corner speed.
4. drive train effiency has improve to a point where it there bettween 1 and 2% loss due to belt wrap or the friction of the bevel gears.
5. bodie shell have become aerodynamic effiecent rather than realistic therefore the downforce and low drag has increased top speed and grip
6. Battery voltage has increase incapacity over the last two years.
The question is what do you change as slowing them down isn't really going to make them slower.
For anyone information about real classes such a group b rallying and c-class racing it was the organisers that killed it off as the got scared of the risk being too high rather than the driver and manufacture plus the rs200 was very underdevelope when it killed those spectators.
sorry, slightly off topic,
1. I believe rs200 is not underdeveloped, its overdeveloped like others group B.. if you remember those big upfront and rear spoiler of group B beast, that tell you how difficult getting traction with such power
2. the reason of group B banning is after several fatal accident related to other group B cars not only due to rs200 accident alone > 1st. rs200 in portugal that you mention, 2. toivoinen (Lancia S4), 3. attilio bettegea (lancia 037), those all fatal accident..
#334
Originally Posted by Rick Hohwart
Ok so I am not going to go re-read the entire thread.
So please link to the posts that show MANUFACTURERS comparisons of:
Run time
Brush life
Top speeds
Lap times
Motor temps
ESC temps
Receiver battery requirements
Please show me.
Run time
Brush life
Top speeds
Lap times
Motor temps
ESC temps
Please show me.
Mike Reedy had some Team Drivers test Touring Cars with 4 cells on foam tires. Even back then we were still running 7 or 8 turns with 6 cells, probably around 2002 or 2003. So some tested and dropped to 6 turns with 4 cell packs. They were about .3 to .5 tenths of a second slower a lap. Not a major drop. The motors finished better, the cars were easier to manage and drive for the race.
If you think that dropping from 6 cells to 4 cells decreases runtime you are mistaken. It is easier to make runtime with fewer cells which was the driving force of 12th scale switching to 4 cell only worldwide.
Jeff
#335
Originally Posted by DerekB
Here's something to think about.
Going up in voltage reduces amp draw. So if we went to higher voltage and used lower tuen motors that resulted in similar performance to the lower turn 6-cell in theory we should have the runtime, reduced stress, and speed.
I guess I'll have to set up some test and see what happens.
Jeff
#336
Run time
Brush life
Top speeds
Lap times
Motor temps
ESC temps
Please show me.
Run time
Brush life
Top speeds
Lap times
Motor temps
ESC temps
Please show me.
Runtime, no problem for 5mins
Laptime, about 0.3~0.5sec slower per lap in 13sec track
Motor, 6x2T
Brush life, make it at least 2times longer if you compare with 6T in 6cells, maybe 3times longer
Temp: wayyyy cooler than 6cells
Batt: IB4200
RX batt is needed for safty, as I dont know if it's ok to run without RX batt
Car weight: 1340~1350g
I'm going to test 4cells 19T vs 6cells 23T once I have time, so I might able to give you more number. But like I said, you need to drive/see the car in person to understand 4cells touring.
#337
Originally Posted by tones
just thought i'd share what i found in testing at a local race meet tonight..
track is indoor asphalt ~10-11 seccond lap.
motor used was 7x1, 12° timing for 6 cell, 18° for 4 cell (didn't play with spring tensions - MR 3.8).
dropping to 4 cells reduced motor temp by ~25°C.
lap times were around 0.1 - 0.3 secconds per lap slower.
less blackening on edge of comm from arcing and in gernal looked _alot_ better.
gearing up a few teeth with 4 cell gave best results, if taken too far lap times slowed.
equipment used was ko 302f, ko vfs-1 comp, ko 2413.
no rx pack was used.
amb personal didn't miss any laps in any of my runs.
dont recall experiencing any problems with the servo.
camera doesn't seem to like the close ups so cant post photos, but the brushes from the motor used for the 4 cell runs have only a very slight change in color towards the face of the brush. quite impressed with that after 8 or so runs on it without a rebuild, some of which in practice well exceeded 5 minutes.
plan to continue testing on different tracks as soon as possible.
#338
Originally Posted by Jeff Brown
Interesting. When I run a motor at 2 volts it pulls say 4 amps. Then I run the same motor at 5 volts and it pulls 12 amps. Please explain.
Jeff
Jeff
No explanation needed... you are right.... more Voltage to a motor = more RPM, more current, more temp, more brush burn....
#339
Power (Watts) = Volts X Amps
to achieve the same power with less voltage:
Shebango! Amps go up.
I guess thats the argument for why more current is consumed with 4 cells. That said, if one uses the same motor in a comparison between 4 and 6 cell, less voltage will result in less power and less current.
#340
#341
Originally Posted by TryHard
I personally am in the camp of the end user is the biggest problem. By it's very nature any competitive sport is going to have people pushing equipment to it's limit for an edge...
Maybe it can be helped by equipment manufactuers upping there game in some areas, but really, it is still on the end user.
Thankfully, I'm in the equipment camp that I know has some of the best specs out there (Hi Terry ). At a recent national over here in the uk, track temps were in the 50C's... no problems with overheating.
Ed
Ed
#342
Originally Posted by ttso
I don't have number but this is what I can tell you by seeing my friend's car.
Motor, 6x2T
Batt: IB4200
Motor, 6x2T
Batt: IB4200
So just as eforer said,
The 4cells motor we are using is draw more Amp. than a 6cells motor. Typical figure is 10-15Amp. @ 2V, 6Tx2.
The speed, may not fast but at least equal when compared to those 6cells modified touring with 8/9T motor in 8 mins racing.
The running time sure no problem for 5 mins, even 7+mins without Rx battery.
One thing I want to mention is: people using 6cells 6T or 7T 5mins compare to 4cell 6T even 5T, the speed of 6cells sure to WIN, it is no doubt.
BUT please be noted that in Japan or Hong Kong. We are talking about 4 cells modified compare to 6ells modified in 8mins racing; it is no doubt both of them are in same speed.
#343
As someone argued when you remove two cells you remove some resistance and as can be seem from the formula, if volts stay the same and resistance is reduced the amps go up. This is actually already part of todays problems as the current crop of cells have half the resistance we had about three years ago...
Originally Posted by Josh Cyrul
tonyv - Actually, we probably wouldn't change gearing. Example - If I drove really hard on the brakes and throttle I had about 750mah left after a run. If I drove just to reduce the wheel spin off the corner (still heavy braking) I came back with about 1100mah. I think all we would do would be a slight timing/spring adjustment and we have 2000mah+ left to make that 8 minutes
Originally Posted by Oscar Jansen
You can see it different: We have less cells, but same weight = more load (A) on motors/batteries/speedo. If we would have less weight we would accelerate faster, but arrive with higher top speeds, and than we have to brake harder = more heat (remember, the tyres stop us to go faster through the corner)
We have to decrease also average Amps.... and this you can only do this with: runtime....
So, 4 cell-6m could be an answer...
Switching to the driveability considerations for a second, one of the reasons it is more difficult now than in the past is the sheer torque we run with. This results in major abrupt weight transfers in the car when going on and off throttle. The top drivers are able to control that, but most of us have trouble with that. This is especially the case in today's point and shoot style of driving caused by the fact that we don't have any runtime problems anymore and therefore basically are running 5 minute sprint races.
Reducing the voltage will reduce the torque and increasing the race length will, as Josh pointed out, result in running less timing and softer springs when running brushed motors. All this reduces the torque and thus the torque effects.
#344
Originally Posted by tonyv
I am not an electronics expert, but I think you've got that backwards. Power is indeed a formula of the Volts times the Amp draw. But the Amp draw is defined by another formula, namely Volts = Amps x Resistance. If the volts go down and resistance stays the same then Amps go down too. The result is less power (volts x amps).
For example, lets say 100W are required to move X ammount of weight and you have a 10V source. (For simplicities sake, lets pretend that the motors efficiency is 100%) That motor will demand 10A. Lets now reduce the source to 5V. It still takes 100W to move the weight, so now the motor will demand 20A. When you factor in the efficiency (or lack of) of permanent magnet DC motors, it starts going down hill.
#345
Originally Posted by Faiz
IMO the concern is not to reduce speed instead simply how to avoid the overgrowth of battery progress overtaken esc+motor combo progress and simply killed them,
Yeah I know First off all the rs200 had a massive turbolag problem and a floppy chassis i know this from talking to guy that raced them in rally cross. This made them really hard to drive and the turbolag would catch you out that why 8 spectators bore the brunt off it the other cars went past the spectator no problem. The Lancia the went down the cliff killing the drivers let just say the the fuel the were using init wasn't 85 octane petrol it was a blend of avgas and some other combustant it was reffered to as rocket fuel and aluminium tank weren't exactly safe for storing it in, in the event of an accident compare to mordern kevlar fia approved tanks. There are a lot a thing about the cars run that unless you know people that have race and delveloped them since '86 you won't know about. Like the 6r4 4wd system was nowhere near developed to cope with 500 bhp of the 3.2 v6. A mate had to spend 30 grand on getting thing like that sorted out to race it. Shame he sold he said it scared the s*** out of him going down brands hatch straight it was doing 140 mph and had more to go and this is a rally car .
