Old 07-13-2006, 09:35 AM   #301
Send a message via AIM to WhoMe
I think some people are confusing runtime and voltage. This idea of reducing the number of cells is geared to reduce the voltage not runtime. However as stated above the runtime will suffer...but thats not the focus.
WhoMe is offline   Reply With Quote
Old 07-13-2006, 09:39 AM   #302
Rick Hohwart's Avatar
They go hand in hand. Reducing the voltage will possibly solve the heat problem, which is the original issue. It would be tragic to go to 4-cells and solve the heat problem and all of a sudden run time becomes the issue, don't you think?
I mentioned earlier in this thread than nobody had even tested 4-cells. It HAS been tired, but until we know what the actual effects of the change are (run time, speed, lap times, motor and brush life), and if they even solve the heat problem, it is premature to make such a drastic change.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 07-13-2006, 09:42 AM   #303
tc3team's Avatar
Just to clarify my thoughts on 4 cell 27,you probably won't need the runtime anyway so to knock off 2 cells surely won't be a big deal.
The main issue is with modified,where the amp draw/discharge? are higher... (think I got that bit right,lol).
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-13-2006, 09:59 AM   #304
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Just a thought - if we drop from 6 to 4 cells. . .we're already having some issues with BEC voltage with some of the new receiver and servo systems out there. . . won't dropping 1/3 of the voltage possibly exacerbate this?
(I say this knowing that the ESCs DO some voltage regulation to the BEC circuit. . .)
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 07-13-2006, 10:08 AM   #305
vtl1180ny's Avatar
We'd probably have to run a reciever pack.
4 cells will also kill 27 turn as the spec/stock class, the cars will be brutally slow.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 07-13-2006, 10:09 AM   #306
tallyrc's Avatar
and once you add a receiver pack, so much for the weight savings of dropping two cells
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-13-2006, 10:11 AM   #307
Suspended
McSmooth's Avatar
Lightbulb
*cough*
5 cells
*cough*
McSmooth is offline   Reply With Quote
Old 07-13-2006, 10:14 AM   #308
TC Guy's Avatar
Today 12:09 PM
tallyrc and once you add a receiver pack, so much for the weight savings of dropping two cells
5 cell mini receiver pack is still lighter than one Sub-C.
TC Guy is offline   Reply With Quote
Old 07-13-2006, 10:19 AM   #309
tallyrc's Avatar
Originally Posted by Rick Hohwart
Not exactly. Battery capacity does remain the same, but you have reduced the packs available energy (which is the point in the first place). Less energy could very well result in less run time.
i'd like to see some real testing on this either empirically under race conditions, or by discharge testing.. losing two cells may cut "energy" (mwhr) but some will be recouped by less resistance becasue of the lack of 2 cells.. under certain conditions 4 cells can be more efficient that 6.. run time will be affected, when people try to compensate for the lack of voltage by once again gearing up or increasing timing...
maybe a timing rule is in order???
Old 07-13-2006, 10:29 AM   #310
Patriiick's Avatar
in mod ?
Patriiick is offline   Reply With Quote
Old 07-13-2006, 10:32 AM   #311
Dropping to 4 (or 5) cells WILL result in more problems not least with personal transponders missing laps, luckily at MRT we have developed the i-PT (our own improved personal transponder) which can run without any problems at lower voltages.
With 4 cells the extra weight of a touring car would mean more potential problems due to the volt drop under hard acceleration or from the current draw of high power servos. A receiver pack would be needed to avoid problems, so more weight to add to cars plus rx batteries to buy and charge etc... is this really such a good idea?
We are of course talking about in the future, right now there are no major problems that need fixing, unless batteries are likely to exceed 5000mAh most existing electronics should be fine and not suffer from overheating. Thermal shutdowns are not what the majority of racers experience in Mod TC even in hot countries.
It would be good to know if we are likely to ever see 5000mAh+ cells, there must be an upper limit to the capacity of Sub C NiMH batteries!
Terry_S is offline   Reply With Quote
Old 07-13-2006, 10:35 AM   #312
Boomer's Avatar
It wouldn't be the weight I'd be concerned with. . .it would be the complexity of yet another component to worry about, another battery pack to make sure is charged, another connection and plug and wire to make sure don't get snagged or unplugged. . . you know?
Old 07-13-2006, 10:45 AM   #313
Josh your right about the 10 to 15 cars on the track. After thinking it more over, I can your point. It was 4 am when I wrote it. seemed like an intreging idea.
I will be looking forward to see the out come at Vegas this Sept. Just curious is there another major coming up that is on asphalt this summer. would like to see the out come of that too. Also to see what the top drivers are doing to keep everything in check.
I guess time will tell. At least were concerned now before it's to late.
cyrrus is offline   Reply With Quote
Old 07-13-2006, 10:45 AM   #314
Sorry I meant that the weight of a heavier car compared to 1/12 cars would make more problems. Yes I agree, with a receiver pack there's more expense, more to maintain and charge, more complication and more hassle plus more potential problems
Old 07-13-2006, 10:59 AM   #315
Conrad's Avatar
From alot of the comments i've read braking seems to be one of the main problems with heat buildup in the esc and motor but can anyone tell me if there is any difference in heat build up between a spool and a diff?
I imagine there would be cause you dont need to brake as much with a diff, you can scrub the speed off when entering the turn. Just a thought but if you only allowed people to run diffs (no one ways either) you may reduce heat buildup (if there is a difference?) and you will slow the cars down and also reduce the chance of breakages. Might even reduce the cost of new kits as you wouldnt really need alloy/titanium driveshafts anymore.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
2006 Ifmar 1/12th & 1/10th Istc Electric On-road World Championships Danny Teh Malaysian R/C Racers 1 02-16-2005 10:38 AM
2006 Ifmar 1/12th & 1/10th Istc Electric On-road World Championships phlim Singapore R/C Racers 3 02-16-2005 09:52 AM
2004 IFMAR ISTC & 1/12th On Road Worlds at Full Throttle Speedway AdrianM Electric On-Road 2162 12-29-2004 04:09 AM
2004 IFMAR 1/12th and 1/10th ISTC ELECTRIC TRACK WORLD CHAMPINSHIPS Marcos.J Electric On-Road 55 02-10-2004 09:05 AM
2003 Ifmar ISTC 1/10 on road???? Wilfred Electric On-Road 2 09-01-2003 05:39 PM
