Old 07-08-2006, 08:15 PM   #1
Default Fk04 Steering problem
Seems like everytime i accelerate hard, the whole steering unit steers left alittle bit (maybe around 3 degrees) automatically. I also tested this by taking my tires off and it seems to have the same problem. Any ideas? Thanks in advance for any help.
RandomTask is offline   Reply With Quote
Old 07-08-2006, 08:26 PM   #2
PitCrew's Avatar
First: make sure your top deck is aligned properly. The plastic pieces that hold the bellcrank shaft are NOT symetrical.
Second: Make sure that your diff is not angled. It could be if you put it in and didn't pay close attention to the belt tightening adjustments on both sides of the diffs (the black plastic peices that notch into scallops in the bulkheads)
Third: Make sure that there is no binding in the drive shafts, like the bearings are going out on one side, or if your using blades on the outdrives-that one of them isn't broken.
Fourth: Check for tweak in the chassis. Loosen the screws in the top plate, and the screws that attach the bulkheads to the bottom chassis, and retighten. Bottom screws first, then press down on a flat surface and tighten the top deck.
If you go through the car complete, and can't find the problem, it could be some type of a glitch with your electronics.
PitCrew is offline   Reply With Quote
Old 07-08-2006, 08:36 PM   #3
jarrodh's Avatar
also make shure your servo is secured, ive had mine comloose and have kinda the same thing.
www.irocc.ca
jarrodh is offline   Reply With Quote
Old 07-08-2006, 09:19 PM   #4
I had a similar problem with my car a bit ago. Sounds like mine was a bit more erratic in that it went both right and left upon accelerating. Ended up being a bad pot in my servo.
wcalaker is offline   Reply With Quote
Old 07-08-2006, 09:28 PM   #5
howard hudson's Avatar
R/C Tech Charter Subscriber
try discontecting the servo tie rod at the servo horn and then punch the throtle. Watch the servo and see in the horn moves under power. if it does try another servo. if it still does it change motors and then if it still does it could be the esc its self or the receiver. could be that you need to use more servo tape to hold down the electronics I use three pieces on the receiver and the esc to better insulate them from the cf.... might be over kill but i dont like to glitch
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 07-09-2006, 12:04 PM   #6
Thanks for the advices
I disconnected the servo from the steering unit and placed the car on a stand. When i full throttle the steering unit would turn left.
I dont suppose tweak could cause this. doesnt seem to be binding parts and the diff is balanced
Any idea from the diagnose?
Old 07-09-2006, 06:23 PM   #7
reread
Steering Problem jmdv Nitro Off-Road 8 06-28-2007 08:23 AM
Shock Problem FK04 Evilstealth Electric On-Road 10 02-26-2007 12:43 AM
MI2 Steering problem brakkie Electric On-Road 6 02-13-2006 07:01 PM
Xray FK04/05 team tamale steering hubs, caster blocks and lowered spring retainers RayWarner R/C Items: For Sale/Trade 5 01-19-2006 05:23 PM
