Old 07-06-2006, 11:51 PM   #31
XrayFK's Avatar
What are they cooling the peltiers with? Fans and heatsinks?
XrayFK is offline   Reply With Quote
Old 07-07-2006, 12:21 AM   #32
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
im ordering a fan kit for my corally... it looks freakin awsome and i think it will help a little not enuf to matter though
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 07-07-2006, 12:49 AM   #33
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
they put a heatsink on the peltier and them put a small fan to blow on the heatsink
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-07-2006, 02:32 AM   #34
jo90's Avatar
This is a subject that has come more to light recently in the UK than before. We are pushing motors harder towards the limit and as such cooling is a must. The 3Racing fans are crap, so many people have said they are weak, and also the fans fins snap easy. Also the way they are wired can be wrong to. The last thing you want is for air to be pushed into the can when you actually want the air to be pulled out (natural airflow from the motor goes outward from the arm). The ideal setup would be
Endbell - Fan located horizontal to endbell pushing cool air into motor.
Can - Fan located and set to pull air away from the can and upwards away from any other cooling fan
The setup in the picture on the last page nigh on perfect. Getting the fan located over the endbell can be a bit fun though, finding 2.5mm machine screws that are long enough can be a task, but once found you can decrease the overall end-run temp by about 3-5 degrees. May not seem much but that overall can give you more punch overall the duration of your race.
One other thing to consider is the use of a 40mm fan rather then the 30's . Though these are bigger, they are actually thinner in width so can slide into locations the small one's cannot. Im currently adapting some servo posts so I can mount one on my Mi2EC ready for a possible hot run outdoors in the UK STCC. Once done i'll post some pics up
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 07-07-2006, 03:57 AM   #35
Best fans I have found is the Associated double pack. Point these fans blowing at your endbell and your motor will come off much cooler. if you want your moitor any cooler wire the fans to 7.2volts instead of plugging them into your receiver.
cockerill is offline   Reply With Quote
Old 07-07-2006, 06:21 AM   #36
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Guo Chean
nowaday you guy can used a small lipo cell to power your 1 or 4 fan in one short no matter how many fan you put it also wont suck so you battery power. you fan will be more high speed becasue lipo have higher voltage
Hi Geo Chean,
Is the fan directly wired into the lipo packs? (no regulator, no switch) And what capacity is the lipo pack (200, 300, 800+mah)???
Many thanks.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 07-07-2006, 07:53 AM   #37
The Much More fans are really good. Better than the Novak clear case ones. The idea behind the motor cooling fan is not to necessarily cool down the motor but to keep the wires from un-soldering. Running 7 turns in 100 degree weather at the recent on-road nats in Roseville was necessary. Every driver in the A-Main of Mod had fans. Some had two or three and none were concerned with dumping.
Tony Vega is offline   Reply With Quote
Old 07-07-2006, 07:55 AM   #38
can we get picks of the mini peltier??
i had this idea but looks like some one beat me to production
cheers, Josh
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 07-07-2006, 08:57 AM   #39
XrayFK's Avatar
cheers, Josh
What exactly was your idea? Running a peltier that is big enough to freeze the motor or substantially cool it is much too big and requires to much power (5-10A @ 12-15v) Anything less you are better using fans which are simpler, lighter, and much less battery intensive.
I have thought about this as well a while ago, using micro sized peltiers on the motor during a run. But even though they are small, they still draw a large current (8A for a good chill) and need to be cooled themselves. After all the extra equipment you have to mount on the car, it's not going to do you much good.
Old 07-07-2006, 10:44 AM   #40
akuhon's Avatar
How about this ....
You might interested .... All it needs is just a good heatsink ...
http://www.arcticsilver.com/as5.htm
akuhon is offline   Reply With Quote
Old 07-07-2006, 11:02 AM   #41
XrayFK's Avatar
Originally Posted by akuhon
How about this ....
What about it? It's just thermal compound, which simply helps make heat transfer more efficient. It basically acts as a heat transfer substance between two objects (metal)
Old 07-07-2006, 11:25 AM   #42
rc-zombies's Avatar
me too... thought about building a mini on-board cooler..using a clip-on heatsink and fan. I've seen the mini coolers on Ebay and runs on 5v.
http://cgi.ebay.com/Peltier-Junction...QQcmdZViewItem
Old 07-07-2006, 11:35 AM   #43
Jack Smash's Avatar
Trader Rating: 29 (100%+)
The biggest effect you will see from the fans is to cool the brushes and comm. Point at least one fan there. The gain you will see from trying to cool the can will be minimal at best.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 07-07-2006, 11:37 AM   #44
XrayFK's Avatar
Yeah, they are small enough. But a couple things. First 4-6 watts is pretty weak, also they need around 5-8A depending on the model, I don't of any small lipo packs that are capable of delivering that current. You could use micro NiMH cells, but those are a lot heavier, so you're not helping anything with weight.
Old 07-07-2006, 06:39 PM   #45
AWK
AWK's Avatar
Has anyone seen the new Integy most coling fan and heatsinks? Are those worth anything. I can't use that setup in TCS, but would be nice for practice and other tracks.
Does anyone sell an endbell motor fan setup kit? I am running the Checkpoint Money motor if that matters.
AWK is offline   Reply With Quote
VENDETTA BL motor reviews.. pros/cons jaejw1 Micro and Mini Scales 121 02-09-2011 05:37 AM
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 07:11 PM
pros and cons MMS2 Rookie Zone 13 11-11-2007 04:30 AM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 08:03 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 01:39 AM
