Old 07-06-2006, 09:38 PM   #16
oracle's Avatar
I have got myself a motor fan from Much More. I must say that it's very strong. I haven't really tried it on my car as i am afraid that the amp draw from the fan will slow down my car. Is this true?
oracle is offline   Reply With Quote
Old 07-06-2006, 09:39 PM   #17
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
i use one b/c if i dont my motor gets hot.. to hot
but i drift, so i guss i have diffrent stress loads then racers do
thedudeaturdoor is offline   Reply With Quote
Old 07-06-2006, 09:40 PM   #18
Jochim_18's Avatar
Originally Posted by XrayFK
You want to use a 5v fan, the 3Racing fan is weaker than the MMR one. The real measure of a fan is not the amps but airflow measurement. This depends on RPM but also on the fan blades.
If you don't think it does anything then don't use them. Other people think they help so they will use them.
Also, your batteries are not going to dump because you run a fan.
I'm not saying don't use them me myself are using this fans but like I said the cooling effect is very minimal.
But I might try different ones like this RADIOSHACK MIRCO FAN and see what happens.
My question is not toward the MMR/3-racing FAN, But to Radioshack cooling fan that I stated above since it requires lots voltage will this drain your batteries down if you used them?
Old 07-06-2006, 09:43 PM   #19
Jochim_18's Avatar
The amp draw that MMR fan is less than the 3-racing that I used I don't have any problem with it so you should be fine.
Old 07-06-2006, 09:44 PM   #20
Jochim_18's Avatar
One question does the air needs to blow directly to the motor or away from the motor to dissepate heat?
Old 07-06-2006, 09:51 PM   #21
m i g v e a's Avatar
i believe it must blow out.... where should you connect the fan to power it anyway?
m i g v e a is offline   Reply With Quote
Old 07-06-2006, 10:10 PM   #22
Jochim_18's Avatar
So the FAN needs to draw heat out the motor?
Where can you get muchmore cooling FAN here in U.S and I'll try one?
Old 07-06-2006, 10:16 PM   #23
Jochim_18's Avatar
Originally Posted by BringItOn
hey. does the Team MM fan fit direct on the 3-racing clamps?
cheers
I've seen at speedtech they have MMR FAN that measures 30mm X 30mm but it's out of stock, But this will probably fit to 3-racing heatsink co'z the
3-racing fun is measured pretty muh the same. That is if your Fan is measured like this.
Old 07-06-2006, 10:16 PM   #24
nexusracing.net has them.
galakawitz is offline   Reply With Quote
Old 07-06-2006, 10:37 PM   #25
XrayFK's Avatar
That fan is 12v, so it'll never get the voltage it needs from your battery pack.
XrayFK is offline   Reply With Quote
Old 07-06-2006, 10:39 PM   #26
XrayFK's Avatar
The fans will not slow down your car.
Old 07-06-2006, 10:41 PM   #27
XrayFK's Avatar
I would stick with blowing air at and over the motor. The endbell specifically, since blowing air at the outside of the can will do next to nothing. Blowing air to the endbell will help keep cooler air around it which dissipate heat.
Old 07-06-2006, 11:01 PM   #28
killingtime's Avatar
I've read somewhere in these threads , that the cool air will be pulled into the motor at the endbell and hot air exhausted thru the vents in the can. SO, if this is true, blowing a fan at the can will actually make the motor hotter since it is impeding the natural flow of air.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 07-06-2006, 11:35 PM   #29
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
nowaday you guy can used a small lipo cell to power your 1 or 4 fan in one short no matter how many fan you put it also wont suck so you battery power. you fan will be more high speed becasue lipo have higher voltage
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 07-06-2006, 11:44 PM   #30
Guo Chean's Avatar
i had read the japan rc magazine now they trying to used the smaller peltier them put on the car power by Lipo it have succuessful to reduce the heat after 5 min i will try to scan it and post here later
VENDETTA BL motor reviews.. pros/cons jaejw1 Micro and Mini Scales 121 02-09-2011 05:37 AM
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 07:11 PM
pros and cons MMS2 Rookie Zone 13 11-11-2007 04:30 AM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 08:03 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 01:39 AM
