best street p-lot car >
Old 07-07-2006, 06:19 AM
  #16
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by thedudeaturdoor
i changed to the black belt b/c i wanted the extra strength
but i did fone on the stock one, i used it for 3 months of heavy bashing and it was fine, but i use 19 and stock motors, as for mod i dunno
that's the only car i have owned, so i cant really compare
I'm confused on your statements about the XXXS and the black belt..The black belt is longer than the stock yellow or blue belt, It takes a longer idler arm to take up the extra slack, It was sold as a kit, You got the belt, pulley, and longer idler arm. I have used them and never ever had any problems with them. If you just bought the black belt by it's self and used the stock idler arm it would not work to good. The black belt was never sold or intended for "greater" strength, It was sold as a performance up grade, It makes the drive train a lot freer. For parking lot "bashing" their is no better car. It's not as cool looking as a carbon fiber double deck chassis with all the aluminum, But for a parking lot car it's the best, You can still find them for cheap, you can still get parts for them, And they have a lot of room for your electronics..you don't have to have micro electronics (remember the smaller it is the more it costs.. ) The TC-4 is not bad but your spur gear is exposed and can get damaged. The XXXS is still fast and a very capable car on the track as well.
Oasis is offline
Old 07-07-2006, 06:27 AM
  #17
Tamiya tl01 eveything that could be damages i.e spur/pinion sealed if you look around in the forums or ebay less than a $100 sometimes can't bet it for bashing thing is a tank the only thing no oil shocks ,my son has been driving his for the past 3yrs. only replaced the front hub carriers.
sportracer is offline
Old 07-07-2006, 06:32 AM
  #18
Why would you buy a TL-01 for $100 when a brand new TT-01(which is a newer car) in the box is about $80
Jay
pyro18t is offline
Old 07-07-2006, 06:53 AM
  #19
hey man i kinda agree belts and stones dont mix so either the xxx-s or a shafty
as for striping spurs and pinion it happens but if u find they get caught between the chassis try a smaller spur, my might used to pick up rocks every meet and went thru spurs like packs (recharging) and i dropped 6 teeth hads the same spur for 4 months now
all cars listed are good but i must say tc4 and ta05 a probablt better than a tb or tt01. i have never drove them.
if ur running 19t or stock go tc4 nice car upgradaple and in america it sound like spares are every where.
have fun with which ever car u like
aus jd 2703 is offline
Old 07-07-2006, 08:05 AM
  #20
thedudeaturdoor's Avatar
it kept poping off, and i had it just like it sadi to have it
and u know u have to take tthe sway bar off, shock tower and all that crap to put it back on, and it was happining one or twice per day
so i said screw it, and my car wasd breaking more than my step-dads tc4
and hes had the car for 6 months amd is still on the stock spur, and the parking lot we race on has a LOT of rocks
thedudeaturdoor is offline
Old 07-07-2006, 08:36 AM
  #21
Oasis's Avatar
You had to have installed it incorrectly or you were not using the longer idler arm, You are the first person I have ever heard of that had any problems with the black belt kit.. (their were a few but once we installed the belt correctly..no more problems) ..You were using the longer idler arm..right? It took me a few times to get the belt installed correctly but I could tell by all the slack that it would not work so I worked on it until I had the correct belt tension. If your belt came off once that should have been an indication that it was not installed correctly..That's Not How Losi Rolls.. I'm not "bagging" on you..But I owned a hobby shop and a "few" guys had a similar problem and they swore up and down it was installed per the instructions..But once we fixed the routing of the belt no more problems. This is why I came to the conclusion that you had installed it incorrectly. Look at it this way..Read the XXXS thread..No one else has that problem with the black belt..
Oasis is offline
Old 07-07-2006, 09:07 AM
  #22
yeah, i must of done it wrong
but i rather have a shaft anyways, i drift and my step-dad has one so i can use his spare parts
Old 07-07-2006, 10:14 AM
  #23
nekmiyevo2's Avatar
wait, so is it fine to drift in a tennis court and play grounds for a TA05?
nekmiyevo2 is offline
Old 07-07-2006, 10:16 AM
  #24
I think that you might have a hard time drifting a tennis court, they are designed to have HIGH traction for shoes. I would think asphalt would be best, maybe a basketball court or somthing like that.
Jay
pyro18t is offline
Old 07-07-2006, 12:11 PM
  #25
pyro18t I'd spend a $100 because you would hop up's and extra's 80 bucks for a new tt01 plus 40 bucks s&h as seen on e-bay =$120 .used maybe no s&h from some one on the forum.
Old 07-07-2006, 12:19 PM
  #26
yeah, so long as ur using abs
but u wont get as much angle
a blacktop or p-lot is best
and post any questions i have about drifting on yhe "Offical Drift thread"
and i know i cant spell
Old 07-07-2006, 12:30 PM
  #27
http://www.rctech.net/forum/showthread.php?t=120660
someone with 2 tl01's and xxx-s for sale.
Old 07-07-2006, 01:06 PM
  #28
Yeah you do have a point.
Jay
pyro18t is offline
