New Novak Stock Brushless
#406
Originally Posted by CRASH
This motor is nuts! Touring Car Foam Tires CO27 I was running a 100/34 with 56mm tires, rollout was 27.34
Put this motor in the car same gearing and a total slow poke. Changed to a 88/40 56mm tires, rollout was 36.55 and what a difference. I think I could still go up a couple of teeth on my pinion or go down even farther on the spur gear.
Just totally insane!
Later,
Later,
What ESC were you using?
#407
Originally Posted by slicvicpr87
Did you run this motor at Willis????....how was it on the track?
I'd love to resolve my other problems, too bad one of them involves surgery on the nut behind the wheel...
#408
Originally Posted by Glowster21
Crash,
Later,
#409
Super Moderator
Later,
Later,
motor came off cold could gone up 2 more teeth on the pinion but the had no room to move the motor i need a smaller spur (like a 80 or 83)
#410
Later,
Later,
OK....MOON gear ratio here I come.....
#411
Originally Posted by Solara
Because of what you said.......I will try to gear my 13.5 to the MOON this sunday just to give the 13.5 another try. I was quite conservative last time (C027 on Mi2EC with 116/32 - foams 56mm, and same car with 13.5 and gearing 116/36, 4T higher only - foams 55mm) I was not impressed at all last time. But after talking about that here...........I think I was WAY undergear...way under. I have 112 spur and 110 spur with 38T opinion is the biggest that I have to try.....
Later,
#412
After talking to a couple of people they all agree that the 13.5 needs to be geared higher then the 4300 just for the fact it is a torque motor. But yeah after the first run I was very dissapointed. But after the main I was very pleased.
Later,
Later,
I just can't wait....................
#413
Originally Posted by vtl1180ny
Yes.... I love it.... Come check out my car, if you want to take a few laps, let me know....
#414
Niice....i gotta check it out this sunday if the girlfriend/slavemaster lets me out to play.....lol were you running a 19t this past sunday?? i would like to see this BL in your car ....This thing is kind of expensive tho! 70 dollars for a stocker plus around 200 for a ESC....but then again you wouldnt have to worry about anything after buying this....im gonna bring my 12th scale back out this weekend
#415
Later,
Later,
Pete
#416
R/C Tech Elite Member
I just got my first SS13.5 and am running it behind an LRP Sphere ESC. At my local track, I gear at 20/86 for a CO27 Stock motor, 19/26 for a Monster Stock Motor and 23/86 for a Sports Tuned. Any ideas where I should be running the SS13.5? I know the guys running Mod 4.5's run around 16/87. (BTW this is 1:10 tourer using an X Ray FK05/T2 ratio)
#417
I would start about 26/86 and work up from there.
#418
Yes, it is hard to believe, I am doing the exact smae thing this sunday (from my last try 36/116) I am going to try from 32-39 with 110 or 108 spur....give me a 35-38mm roll out with 56mm foams. If you are running rubber tires, still, try from 26T and go up....probably don't need to go all the way up to 36T...
Good luck...
#420
Anyone have some advice on how I should setup the profile of the GTB with the 13.5? Is anyone running anything other than one of the stock profiles?
