New Novak Stock Brushless
#391
Originally Posted by vtl1180ny
So we're pretty much saying a 50-60mm rollout here???? Possibly even higher....
#392
For Brushed mode- Is it possible to make some type of harness at the speed control that connect all three wires that are suppose to go to the negative pole on the brushed motor and have only one wire go there instead? Or do you have to have all three wires from the speedo go to the negative pole.
(Hope this question makes sense)
#393
And here is a setup with a Brushed motor:
these are not mine but i found it from last year!
Hope it helps
#394
Wow, thanks Marcos. These pics are very interesting. I wonder if it's possible to hook something up closer to the solder tabs of the speedo. I appreciate the pics very much.
#395
Originally Posted by racenut123
Try a 66mm rollout.Its definately funny to see your lap times are almost exactly the same after 8 minutes.Also what temp are you motors coming off the track in a 12th scale? My speedo was at 75 degrees and the motor was at 94 degrees.Crazy! Anyone else with some feedback?
#396
MacroJ.......I am sure NOVAK system has 1 extra wire then the LRP system for brush motor use. But I know you are only showing the concept here....that is a very clean setup.
If I have to wire the GTB to brush motor, I will try soldering the 3 color wires onto a battery bar "across" and then solder 1 black negative wire on the other side, then solder then end of that negative onto the brush motor.
May not be the cleanest, but probably easier then soldering all 3 wires onto the motor very space limited negative side tab.
#397
#398
Originally Posted by HB Moose
Here is the schematic for my brushed/brushless set up. I have the brushless done and on the car and Im making the brushed add-on now. I cut a Deans connector in half to make the single connectors.
#399
Xtreme RC Cars December issue shows 2 great pics of how to wire the Sphere and GTB up to a brushed motor on page 177. Small jumper wires on ESC then 1 wire to each pole on motor. Cleanest way I've seen yet. Although I don't use brushed motors anymore
#400
#401
I'm hoping someone can clear something up for me. I'd like to put the sintered rotor into my 13.5 but I have a few questions.
Should this just drop into the 13.5?
What end bell is supposed to come on the 13.5?
How can I tell what end bell came on my 13.5?
I've been running this motor in the local stock/foam class and I love it. It's like having a fresh tuned motor every run.
#402
(1) yes....plug and play
(2) it suppose to have the big bearing end bell (or should I say front bell)...the eariest verion has the 4300/5800 old style...(i think)
(3) If you see the bigger bearing one...that is the latest one. My 13.5 one is exactly the same (bearing wise) as my 4.5.
I am glad you like the 13.5 stock at your track, I am still trying to get more gearing things figure out and try to catch those tunned brush motor....my 13.5 still a little slower...
#403
I asked that question a week ago, and here are the answer....
#404
This motor is nuts!
Touring Car Foam Tires CO27 I was running a 100/34 with 56mm tires, rollout was 27.34
Put this motor in the car same gearing and a total slow poke. Changed to a 88/40 56mm tires, rollout was 36.55 and what a difference. I think I could still go up a couple of teeth on my pinion or go down even farther on the spur gear.
Just totally insane!
Later,
Later,
#405
I think I found a happy medium at 55mm rollout.... I had too many chassis issues last week and broke my car every round.... My motor was barely getting warm the week before and I had no noticable temp change in the ESC...
Did you run this motor at Willis????....how was it on the track?
