New Novak Stock Brushless
#271
Originally Posted by James35
It must be my meter then, because if I stop moving the rotor, it always falls to 0.00. It sounds like yours does not do that.
{a minute later}
Crap...you got me thinking. Was it 0.0 or somthing else...hmm...if i unsolder the motor wires and leave it in the car......
#272
Originally Posted by brownpants
I mailed Steve about running the ss4300 motor in the 19T class for your club/winter series and he was ok with it. But I'm wondering whether to wait and get this stock motor now?
Do you know if this will be sold as part of a system? Or just the motor?
Darren
Darren
#273
This year's Indoor Champs at Cleveland will be VERY interesting, as they are allowing BRUSHLESS motors (manufacturers subject to Mr. Bills aproval) to run in the mod classes, along with the brushed. I know at last years Halloween Classic at the Gate, Barry Baker was running a BL motor during the open practice sessions, and the car was faster than with his 'team' brushed motor. So, what will the top dogs in mod classes be running this year at the Champs?
#274
Just got my 13.5 yesterday. Tried it at the track today. I was kind of disappointed with the results. (at least for this first day of testing) It was pretty slow. I was getting passes on the straight and it did not have the punch that I have seen in novak's other brushless motors. I do have to admit that I did not have time to work with the gearing, but I was using a 7.33 : 1 ratio.
I used a 7.0 : 1 ratio with a SS4300 the past year and that seemed more like a very good 27t.
We'll see, haven't given up yet. I might just get the velociti 3.5 and race mod; love that power and speed.
#275
#276
Yea, it's 3 full turns lower than a 4300 (10.5T) so it's going to be slower. Most people seem to think it's right on track with a fast 27T when geared properly.
So, where's a good place to start gearing this thing? I generally speak rollout since we're on foams, but I can figure out ratio too.
#277
The magnets in the 13.5 feel much stronger than the 4300 when I turn them by hand. The 13.5 feels a lot more like a brushed motor with a lot of magnetic resistance, where the 4300, 5800, etc. are very free and smooth. Is this because of the increased wire mass inside the cans with the additional turns? I'm guessing this is the same rotor as the upgraded one in my 4300, and not one that was specially designed for the 13.5. I say that because supposedly you can used the sintered rotor in the 13.5, and I don't see one for sale specifically for that motor.
#278
The 13.5 comes with the older style endbell and rotor, like the 4300 and 5800. This means it can't take the sintered rotor, but probably can take the SS upgrade kit, and then in turn take the sintered rotor.
Obviously, since it's tuned with being true to stock in mind, you wouldn't want to make these changes. Just an FYI though, I hadn't seen it mentioned elsewhere.
#279
Well, I have only run it on rubber tyres outdoor on asphalt - to see the track go to www.wlrc.co.uk - straight is about 110ft and track length is around 700ft depending on track layout.
My normal Monster gearing is 6.0:1 = 33mpr.
On the 13.5 I am at 5.6:1 = 35.3mpr
#280
Ran the 13.5 tonight. Man, that thing wants some gear. I ran out of pinions after I put a 40 on there, and it was still under 130 degrees and clearly ready for more. Even at that gearing (rollout around 32.5mm) I was real close to the other guys. My batteries aren't the newest, and I could definitely give it more gear, but I wasn't at much of a disadvantage. Other people watching said it had a bit more rip out of the corners than some of the other guys, but I imagine gearing it up will cut that down and help with top speed, where I was maybe just a tiny bit off.
I do believe Novak has a winner. For club racing, at least, my initial impression is that the 13.5 should be readily allowed in stock class for the guys interested in running it.
#281
Now that you tested the motor and found the same thing I did.As I have said this is the way to go. Now it's time to get rid of my old equipment for a brushed motor.Just curious where do you get those numbers.Are there any charts and how do you use them? We run rubber tires down here.
#283
I'm still waiting for mine to come in,
what pinion would you suggest to run with my pro 4's 98t 64p spur gear on an indoor carpet setup?
#284
I have run mine twice this week. Once indoor on a tightish track at 6.19 on 63mm rubbers and would have liked to try 5.95. Today outdoror on a medium sized track and at 5.16 it was close to the best Co27's around here - not making over 120 degree at the end of the race. I'm very happy with it - will continue testing but think it's the future for sure.
#285
Originally Posted by syndr0me
Like when we all put sintered rotors in our 13.5's and 4300's? :-D
Do you think the GTB will need the fan when running with the 13.5? What about the 4300? I ran without it at times, and it seemed to do just fine.
Another suggestion, you can always call Novak tech support to ask questions. I had slow time getting through but was pleased with the technical understanding and answers I got.
