Old 07-06-2006, 08:37 PM   #16
Drewdc90's Avatar
You should probably try a 25 to 26 rollout, I gear my D6 8X2 at 23.5 to 24.5 and it seems alright.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 07-06-2006, 08:53 PM   #17
Send a message via AIM to waterblast02
Originally Posted by Drewdc90
What rollout did you run?
I used gearchart.com and it says my roll out was about 20.5.
Im seriously hoping its not too bad. The wires inside werent discolored or melted or anything. Think a new cut and new brushes would maybe fix this? And Ill check about any seized bearings. So would a rollout of 25 be best next time I try to run this kind of motor? What kind of rollout for a stock motor?
waterblast02 is offline   Reply With Quote
Old 07-06-2006, 11:17 PM   #18
Just out of curiousity...you have the schottky diode on your motor? i have the same esc and it doesnt have an internal one......i dont know for sure but i have heard that it can mess up your esc and possibly your motor.
wcalaker is offline   Reply With Quote
Old 07-07-2006, 12:12 AM   #19
Drewdc90's Avatar
If it did over heat it definitely wasn't from over gearing but could have been from under gearing.
I gear my 4.5 around 20 to 19.
For a stock motor like a monster a 32 to 34 rollout would be a good starting point.
What timing were you running?
Old 07-07-2006, 06:24 PM   #20
The timing was set to 25. That what it was when I bought it from the shop. Im looking over it again and I think it might be a brush problem. The bottom of one of them has a bit of coloration.
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
How to fix old seized (not overheated) engine? Mike Schumacher Onroad Nitro Engine Zone 5 04-29-2007 08:42 AM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Brushed motor clean out - XIPP LATHE / PEAK VANTAGE MOTOR RUN---ChEaP--- wannabee R/C Items: For Sale/Trade 10 03-10-2007 06:30 PM
overheated stock motor raceblast Electric On-Road 10 12-16-2004 02:57 PM
