Old 07-30-2006, 12:05 AM   #76
Looks great. Wonder what the price will be? I know someone mentioned around $200 but i cant see it that low. Probably more like $299 or somewhere in the range that it is cheaper for you to buy the T2R but not so cheap to buy a T2R and hop it up and still be less than the T2. My bet is $299.
wcalaker is offline   Reply With Quote
Old 07-30-2006, 12:07 AM   #77
XrayFK's Avatar
The price is 199 in Europe, so around 250USD.
XrayFK is offline   Reply With Quote
Old 07-30-2006, 12:28 AM   #78
Ill maybe upgrade a little, like get the alu posts and a battery strap.
slowandsteady is offline   Reply With Quote
Old 07-30-2006, 01:11 AM   #79
big al's Avatar
The question I have is.. WHEN??
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 07-30-2006, 05:08 AM   #80
XrayFK's Avatar
Unless you are running carpet, you most likely won't need the posts. I personally wouldn't use a battery strap, as it's another tweak source to worry about and there is enough weight on the battery side as it is. A good roll of tape should only cost you about $10 and it will last a long time.
Old 07-30-2006, 09:37 AM   #81
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
The only drawback for using the car as is, is the diffs. I believe that in mod diffs wont last long. Other than that it's another high quality car from Xray
Nick
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 07-30-2006, 10:31 AM   #82
I never thought a battery strap would tweak the chassis. Im just a little over protective with my car and everything in it. I just dont want the battery to fall out and rip off the speedo wires. But that tape bonds to itself verywell so Ill rethink the battery strap. And yes I do run on carpet. I was thinking about it and I think the regualar t2 would be far better for carpet racing because of the less flex in the carbon fibre. So the t2 would be a far better investment in the long run.
Old 07-30-2006, 01:22 PM   #83
Nick
Have you tried the diffs that will come with the T2R?
Tony Vredenberg
tonyv is offline   Reply With Quote
Old 07-30-2006, 04:54 PM   #84
Joel Lagace's Avatar
* The chassis is made of FRP (Fiberglass Reinforced Plastic) instead of CF (Carbon Fibre)
* The wheel hubs are composite, instead of aluminum
* The layshaft for the T2R is solid, unlike the T2's lightened layshaft
* The multi-diff/diff aluminum & spring steel components have been replaced with another material (waiting for confirmation of the material type)
__________________________________________________ _______________________________
Looking at that i must say this car packs much more value in it then the T1RAYCER did for sure. For the outdoor stock/19t racers this car will be hooked up,FRP will give it the flex and you wont cry after a days scrapping on the track. Wheel hubs comp instead of alloy? LOL who cares i raced for years with my TC3's with comp, solid layshaft extra rotating mass ok thats a negative but its minor upgrade if needed. The diffs being comp outdrives would be perfect for stock/19T racing. This car may be the better pick for many racers. IF the price stays low.
As for the upgrade to BMI side of things i guess its a matter of wether or not the BMI is actually the hot ticket for carpet racing is it really better then all the technology built into the T2 chassis. Would the cost of a T2R+BMI be less then or more then a T2? IF more the BMI better alot better.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 07-30-2006, 04:58 PM   #85
actually the t2r is coming with Hudy Spring Steel tie rods and and cv axles.
Old 08-02-2006, 05:16 AM   #86
would this car possibly cost more than 250 us? and about when will it be available to buy?
myk505 is offline   Reply With Quote
Old 08-05-2006, 07:26 AM   #87
wow good replies
Old 08-05-2006, 07:32 AM   #88
XrayFK's Avatar
Neither have been officially announced, unless you can get TeamGP to open his mouth, lol.
Old 08-08-2006, 10:17 AM   #89
Skill's Avatar
The RRP for the UK will be 139.99, looks like an extremely good value car to me! When the T1R first came out it was 220!
Skill is offline   Reply With Quote
Old 08-08-2006, 10:55 AM   #90
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Nick
i think that you will see many drivers using the plastic diffs in stock for sure, and maybe many using them in mod also..
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
