Old 10-07-2006, 11:18 AM   #256
gacjr0's Avatar
Trader Rating: 15 (100%+)
Greatplanes electrifly 3200 mah 7.4V 20C lipo in car
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 10-07-2006, 11:24 AM   #257
gacjr0's Avatar
Common Sense RC 4400 mah 7.4V 10C lipo
File Type: bmp t2r common sense lipo no body cropped.bmp (192.5 KB, 138 views)
Old 10-07-2006, 11:58 AM   #258
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Does the option Solid Delrin T2 front axle (spool) fit the T2R??
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 10-07-2006, 12:03 PM   #259
ChrisP's Avatar
Yes
ChrisP is offline   Reply With Quote
Old 10-07-2006, 06:53 PM   #260
RAL
RAL's Avatar
cool!
Old 10-09-2006, 09:47 AM   #261
Originally Posted by Desolas
I think he is refering to running the car carpet on FOAM tires. Which I agree with him, technically you could run it but because of how soft the chassis is it would be very hard to dial traction out. You'd end up 2 wheeling around every corner as soon as traction came up. The carbon T2 is kind of soft for racing on foam tires, by default that would make the T2R worse.
For rubber though, box stock the car is good and its real easy to get traction with it.
Naw I dissagree the T2R chassis is not as soft as the T2 chassis.
Nobody will have any problem running non carbon fibre chassis with foam tires on carpet with the xray.
mcgmark is offline   Reply With Quote
Old 10-09-2006, 01:40 PM   #262
RCknight's Avatar
Default Does the T2r come with outdrive rings to keep them from
speading under load? Or can I purchase them from Xray?
RCknight is offline   Reply With Quote
Old 10-11-2006, 08:14 AM   #263
gacjr0's Avatar
It does not come with rings in the kit.
My limited time with them suggests they aren't needed.
Old 10-13-2006, 06:12 PM   #264
hey guys whats the street price for the t2r?
dave_dynamite is offline   Reply With Quote
Old 10-13-2006, 09:14 PM   #265
Team Speedy's Avatar
Trader Rating: 42 (100%+)
I paid $199.95 for mine I think. Then parted most of it and made near 1/2 of my money back! At least I got the BMI bits, that all that counts!
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
Old 10-13-2006, 09:37 PM   #266
really?!....on that note i plan on getting one next month then. any tips and suggestions??
Old 10-14-2006, 08:42 AM   #267
Yeah, use the Xray shocks and nothing else! Take your time building them and if you have questions post them in the T2 section thread and someone will reply. Take your time building the diffs and follow the instructions carefully. You might want to prep the chassis edges by sanding them a bit and rounding the edges if you run on carpet. Sand them and CA the sides and you'll have a nice finsh if you do it right. You also want to file the battery slots in so your cells fit nice and snug. Setups are online at http://www.teamxray.com under the setup section. Hope that helps.
Old 10-14-2006, 11:06 AM   #268
Tips..
One thing I noticed the diff covers don't come on a parts tree but they have little bits of plastic that need to be sanded off or they will catch on the chassis and bind the belts.
If you have old or plan on buying new electronics buy the smallest stuff!! chassis space is nonexistant on this car!
also read and read and read the setup manual that comes with the car..
its seperate from the building manual...
I will post more as they come to me..
Old 10-14-2006, 11:14 AM   #269
I second the setup book. READ IT! It explains everything about the car and what this does and that does. Xray has done many, many hours of testing and the book explains what they found while testing. If you follow the book, I'm sure you'll get the car setup right the first time out.
Old 10-14-2006, 12:38 PM   #270
thanks for the tips, i'll be sure to take my time when building so i dont rush things.
