Old 09-26-2006, 10:39 AM   #211
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by macnkitty2002
ok, maybe i should use rubber tires for my asphalt racing.
now that i've changed my mind over tire choice, do you still recommend the sway bars and different springs? should i invest in a multi-diff or is the stock ball diff fine for asphalt?
Your ball will work but I'd go ahead and get a Multi-Diff because a spool is the best choice (most of the time) on asphalt. It will allow you to brake later in the corner adding corner speed and steering. Also, an array of springs is a good idea for tuning - my advice is to see what the fast guys are running and go with that.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 09-26-2006, 11:18 AM   #212
macnkitty2002's Avatar
the funny this is that there are no fast guys (yet) at my track. it's pretty new.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 09-26-2006, 03:29 PM   #213
Dane's Avatar
BE the fast one
Old 09-26-2006, 05:05 PM   #214
well, of course....
Losi Rock Rey
Old 09-26-2006, 08:22 PM   #215
The instructions for building the diff fuckin suck.
and the part bags are labled poorly.
Are the images of the screws, clips etc drawn to exact size?
mcgmark is offline   Reply With Quote
Old 09-26-2006, 08:51 PM   #216
PeteB's Avatar
yup, real BITCH building those diffs, where are you having a problem??
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 09-26-2006, 09:27 PM   #217
Registered User
It's a composite diff...its not THAT bad, all you need is a description. What are you guys having problems with? The exploded view shows how it's done in the supplimental instructions.
The screws are basically to size from what I remember.
Has anyone tested the car on capret with foams?
The car would have a crazy amount of grip with foams, I think it's it will have too much flex to be useful with foams unless your running on a real slick track .. it will make it harder to tune the car I bet.
Desolas is offline   Reply With Quote
Old 09-26-2006, 09:38 PM   #218
It was actually easy. (after we read the supplimental instructions)
Hardest part was getting the little nut set into its place.
But they don't feel perfectly smooth so they will have to be rebuilt.
might have gotten a fibre from the towel in there...
Old 09-26-2006, 11:01 PM   #219
war11x's Avatar
Trader Rating: 17 (100%+)
Default Diffs
hi
just a quick one
are the FK04 following Parts the same as the T2 ? and / or will they fit ?
front one way
rear diff
full shocks ( Xray Alloy)
i have spare of these from my FK4 and it would be a Big + if they do fit
cheers
war11x is offline   Reply With Quote
Old 09-27-2006, 12:37 AM   #220
Patriiick's Avatar
i think you re good for the diffs and one way, the shocks MAY BE too long and might not fit..
Patriiick is offline   Reply With Quote
Old 09-27-2006, 06:19 AM   #221
i thought the kit came with the diffs prebuilt?
Losi Rock Rey
Old 09-27-2006, 06:26 AM   #222
teamgp's Avatar
Originally Posted by war11x
hi
just a quick one
front one way
rear diff
cheers
The one-way and full shocks are not interchangeable. The rear diff is though. Take a look at the XRAY T1 & T2 Parts Cross Reference Table for more questions concerning compatibility.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 09-27-2006, 06:53 AM   #223
Send a message via MSN to ickvanovs
is the t2r upgradable to t2 '07?
what is the different between t2, t2 '07 and t2r?
ickvanovs is offline   Reply With Quote
Old 09-27-2006, 07:23 AM   #224
PeteB's Avatar
nope, you get about 27 parts, spread over several bags... per dif, plus some grease and some iffy instructions
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 09-27-2006, 08:03 AM   #225
Team Speedy's Avatar
Trader Rating: 42 (100%+)
T2 last years model, still top of the line though.
T2 007 this years model. New top of the line car for next year. Geared for carpet mainly with dual diffs lowered bulkheads and a newer 3.5mm chassis. The asphalt version consist of a 2.5mm chassis, multi-diff and lowered bulkheads still. Check out http://www.teamxray.com for the preview they have it. Also check out the T2, T2r, and 007 thread all found on the front page. It will replace the "orginal" T2 soon
The T2r is still the same car as the T2. You just get FRP chassis, upperdeck and rear deck and shock towers. You also get composite diffs and plastic wheel hexes. The T2 would get a full graphite chassis with shock towers and a lightweight diff and alum. wheel hexes. That's about the differences right there. That right there brings the price down. You don't get the plastic wheel dishes either. You do get a full color manuel, setup guide and stuff like that. The set up guide is worth while as it breaks everything down in simple terms to get the full potential out of the car.
On all of the cars the suspension is still the same, same shocks, belts, shock towers ect....
There you go
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
