diff. problems... i think
The rear left wheel has no power when i put it on full throttle, but when i hold the other wheel it moves at full speed. anyone know what the problem is?
Diff too loose, maybe? If your diffs use beveled washers, are they in the correct way? Just throwin' stuff out there.
need more information...
type of car, front or rear diff... |
its on a TA-04, its the rear diff. and its a gear differential.
disconnected dogbone to the axle??
sheared axle pin
rebuild your diff that should solve it.
I rebuilt the diffs but its still like that and the dogbomes are well connected. maybe i should ask my LHS if they can see whats wrong and see if they can fix it for me.
since its a diff and the power goes to the least resistence, im thinkin a stuck or seized bearing in the hub?? thats the first thing id check.
