Old 07-03-2006, 07:28 AM   #31
ok that sounds cool! so which ko propo speedo is worth getting? was there a graphite looking one or something?
myk505 is offline   Reply With Quote
Old 07-03-2006, 07:40 AM   #32
XrayFK's Avatar
The current ones are:
VFS-1 Pro
VFS-1 Pro Competition
VFS-2
VFS-FR
and all the other versions such as
Hara Twister
Corally MMS
Rayspeed/Yokomo Masami
Tamiya Volac
Here is the page with all the info on them: http://kopropo.com/ESC.htm
Honestly, you would be just fine with the VFS-2 or FR, they are cheaper but offer the same adjustability.The reason they are cheaper is because of the FETs, but unless you are running insane mod motors and batts, it's not going to be a problem. All the speed controls come with a cap and diode.
Also, if you can find the older VFS-2000 version for pretty cheap (I got mine for 70 bucks including the setting adapter), that's a good deal as long as you don't mind a slightly bigger esc.
XrayFK is offline   Reply With Quote
Old 07-03-2006, 01:58 PM   #33
Another vote for the MRT MX here. I've had one since they came out and it has NEVER given me any problems. Really easy to use and reliable and a very good price.
ralph_c is offline   Reply With Quote
Old 07-03-2006, 08:51 PM   #34
wats the difference between the pro and pro competition and is the VFS2 better than them?
Old 07-03-2006, 09:50 PM   #35
XrayFK's Avatar
It says it all on the link I posted. Whatever.
The Pro Competition is the exact same except with a higher thermo cutoff and CF design case. The VFS-2 is the exact same except with less FETs.
Old 07-03-2006, 09:55 PM   #36
I still doubt that the speed control is your problem. Before you buy another speed control you should see if someone would trade esc with you to test yours.
Your batts are on the low side of todays cells. What car and gearing are you using? hOW OFTEN DO YOU CUT THE COMM? What brushes/ springs?
VSF1 pro and comp is for those who like to spend alot of time programming and more money on programmers. Most people don't like to do that much on the esc. NOT RECOMMENDED for nebies.
Charles is offline   Reply With Quote
Old 07-03-2006, 10:58 PM   #37
XrayFK's Avatar
That's what I was saying, but he wants to know about the top end esc's. I'm not going to tell him how to spend his own money...
But yes, the VFS are really meant for people who want to fine tune everything. Not worth it if you don't really even tune your motor.
Old 07-03-2006, 11:59 PM   #38
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
was sold on the Tekin G11pro i was using... simple to use out of the box(didn't care much about the programming since i'm a noob and didn't know squat on what and how to program it). well, i was sold on it until i accidentally burned it.
using a Novak GTX now... seems fine. I like that its small and lightweight... the power cap is just a hassle to mount. but everything is pretty much fine once you do.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-04-2006, 03:02 AM   #39
The MX Pro is very easy to set up and use. Having power profiles with both fixed frequency and also variable frequency that are preset for stock and modified etc makes it simple to get it right, just set and forget! For those that want to fine tune everything we have a separate programmer option coming.
Terry_S is offline   Reply With Quote
Old 07-04-2006, 03:35 AM   #40
i was using a new EPIC roar pro stock motor
Old 07-04-2006, 05:32 AM   #41
XrayFK's Avatar
If you don't feel like fine tuning everything on the KO, you can always just download profiles off their website. One thing I applaud KO for is that almost all their current equipment is PC-connect compatible, so you can manage everything on your PC. I would still check your motor though. Get good brushes, keep the comm true, align the brush hoods correctly and make sure the bushings and armature spin smoothly.
Old 07-04-2006, 06:33 AM   #42
so wat is the latest ko propo speedo?
Old 07-04-2006, 06:41 AM   #43
rampal's Avatar
Send a message via MSN to rampal
As far as I know, KO VFS-1 Pro Competition. It is the same as atsushi hara twister 2.1. All the others are copies of the VFS-1 pro (NOT comp).
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 07-04-2006, 09:10 AM   #44
Nicadrauspro4's Avatar
I think there is a slight difference on the profile between KO Propo VFS-1 Pro Comp and Hara 2.1. I'm not sure.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-06-2006, 08:40 AM   #45
thx for feedbak ppl
GT7, KO SPEEDO, CORALLY SPEEDO, LRP SPEEDO superslow R/C Items: For Sale/Trade 0 05-29-2008 08:27 PM
KO SPEEDO AND NOVAK SPEEDO PRICED TO SELL hpiracer0911 R/C Items: For Sale/Trade 0 02-12-2007 09:35 PM
2 RC10GT rollers,good shape,2 good running motors,and many other misc items!!!!!!!!!! tagalong_74 R/C Items: For Sale/Trade 8 12-05-2006 08:26 PM
Trade For Off Road or GOOD Web Site or GOOD Camping stuff Tech_Muggz Other Items: For Sale/Trade or Wanted to Buy 11 11-03-2005 02:59 PM
Selah R.C. Raceway-good racing good people mmotox17 Northwest Racers 6 07-08-2005 10:38 PM
