Old 07-02-2006, 02:02 PM   #16
You already have a top of the line esc capable of winning a world championship.
1st have you read the instructions?
2nd why do you think a small esc is not as good? All of the top esc's are small excluding Tekin.
Charles is offline   Reply With Quote
Old 07-02-2006, 05:57 PM   #17
My quantum 2 isnt as fast as other peoples car's. i got new batteries and geared the car up, and had a new motor, and my car wasnt as fast as a persons non geared up car.
so it leads me to think that my speedo is no good?
myk505 is offline   Reply With Quote
Old 07-02-2006, 07:41 PM   #18
XrayFK's Avatar
Don't blame your speedo for a slow car. Tune the motor and gear it correctly. Just because you gear up doesn't mean your car will necessarily go faster.
XrayFK is offline   Reply With Quote
Old 07-02-2006, 07:45 PM   #19
Sushi Man's Avatar
Send a message via AIM to Sushi Man
random but HEY!!!! XrayFK and I randomly met in a RC shop in JAPAN!!!!! that was pretty darn cool....
you can find some GT7's for cheap....
Sushi Man is offline   Reply With Quote
Old 07-02-2006, 10:43 PM   #20
That0neguy's Avatar
I had a LRP QC2 go up on me no reason other then the 12x2 it was running.Lrp's shit is WEAK.
Hello.0
That0neguy is offline   Reply With Quote
Old 07-02-2006, 11:10 PM   #21
Nicadrauspro4's Avatar
Originally Posted by XrayFK
Size (smaller), amp rating (higher), and drive frequency (adjustable). If you can spend however much you want, get the KO VFS-1 Competition with the handheld setting adapter or PC connection. It allows you to set the drive frequency for each throttle step, braking programs, and other esc settings. It's also very small.
I agree.
myk505,
If you're running brushed motors, then the VFS-1 doesn't need much explanation. It has been proven for a couple of years now and have won many national and world championships already. The KO Propo VFS-1 comes in different sub-brands. Such as Hara Twister, Rayspeed, Corally, Masami, Volac, etc. Either of any will do. As long as the model is VFS-1 Pro or Competition. It's a very good choice that you won't regret.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-02-2006, 11:41 PM   #22
What car, motor, gearing, batteries are you running?
Did you read the esc MANUAL?
Old 07-02-2006, 11:52 PM   #23
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I recommend a Tekin G11 speedo.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 07-03-2006, 12:56 AM   #24
i put the setting on the speedo to the stock racing program (number 5). and the batteries i had were new with good reading (1.182, 2.1 IR, 414+ runtime), i also used a new motor aswell.
Old 07-03-2006, 01:15 AM   #25
Rowdy's Avatar
For Modified racing, LRP v7.1 is still one of the best IMO. Sure its big, but it doesn't hit temp cut, doesn't overheat at all, never blows up and performs just as well as its newer counterparts.
Rowdy is offline   Reply With Quote
Old 07-03-2006, 01:36 AM   #26
That0neguy's Avatar
Im sure its good, but when AE wanted 140$ to repair the thing that was 4 months old and was its fualt.It sucks.So much for their "life-time warenty"
Hello.0
Old 07-03-2006, 02:04 AM   #27
XrayFK's Avatar
Yeah, but what motor? Gearing? Brushes and springs? Usually the brushes that come from the factory suck.
Either way, the KO is the way to go. It's small, but still can handle as much power as you throw at it. I would even use the VFS-2000 over any LRP or Novak esc I have used.
Old 07-03-2006, 02:09 AM   #28
Rowdy's Avatar
Yeah that sucks, did they try to tell you it was your fault for hooking it up wrong? This happened to a friend of mine, the thing blew up four and a half minutes into a race.
Old 07-03-2006, 06:51 AM   #29
so the Ko propo seems the speedo to get? wat setting can i change that will make it perform better etc? wat is this drive frequency and stuff?
Old 07-03-2006, 07:21 AM   #30
XrayFK's Avatar
ESC's don't send a constant current to the motor, it is pulsed. The rate at which it is pulsed is the drive frequency. So a higher drive frequency means that it cycles more times per second. A lower drive frequency gives more power with lower runtimes, and vice versa. The VFS-1 Pro has 32 throttle steps with 64 different frequency settings (0.9 - 12kHz) for each throttle step. So instead of having the same frequency set throughout the throttle curve, you can adjust for more "punch" off the line and out of corners (mid-range) and increase the frequency for smoother top speeds.
You can also adjust neutral brake, frequency of the brake, BEC voltage setting (2.5V-4.0V), throttle response, and current limiter.
GT7, KO SPEEDO, CORALLY SPEEDO, LRP SPEEDO superslow R/C Items: For Sale/Trade 0 05-29-2008 08:27 PM
KO SPEEDO AND NOVAK SPEEDO PRICED TO SELL hpiracer0911 R/C Items: For Sale/Trade 0 02-12-2007 09:35 PM
2 RC10GT rollers,good shape,2 good running motors,and many other misc items!!!!!!!!!! tagalong_74 R/C Items: For Sale/Trade 8 12-05-2006 08:26 PM
Trade For Off Road or GOOD Web Site or GOOD Camping stuff Tech_Muggz Other Items: For Sale/Trade or Wanted to Buy 11 11-03-2005 02:59 PM
Selah R.C. Raceway-good racing good people mmotox17 Northwest Racers 6 07-08-2005 10:38 PM
