Old 01-16-2003, 08:05 AM   #1
Default Tamiya Evolution III & 2-Speed Trans
Just got mine built!!!! Had a few questions:
1) Was wondering if a two speed would work. I also Have a electric boat with 4 neo motors and 4 tranmsission and the thing launches around the corners going from a 1:6 ratio in first gear to 1:1 ratio in second gear. I attached a picture of the two speed and some specs:
*****Powered by the advanced gearing system, NOVA Two Speed Gear Box is able to greatly improve both speed and torque of RC Cars. It provides racers with more steering control over sharp corner as well as the speed necessary for straight tracks. Power consumption and acceleration time is decreased to allow the car to reach max speed faster while providing a longer run time. This is a perfect gadget for racers who want to reach the highest performance and beyond.
*****Dimension 36.5 X 21mm
Voltage 6V ~ 12V (5 ~ 10 cells )
Weight 48G
Gear Ratio (Low speed) 1.6 : 1
Gear Ratio (High speed) 1 : 1
Operation Forward, Brake
*****-Nova Two Speed is an one-piece design, it is easy to assemble and is suitable for most kinds of RC cars.
-Torque and performance have been improved by the advanced gearing system. Power consumption is lower to provide a longer run time.
-Direct power transmission during high speed reduces the friction between gears. The car can run faster & more controllable, especially in high speed cornering.
-There are clockwise & anti-clockwise revolution in the gear box. Use different combinations with different types of cars.
2) Good recommended set-up for a medium size track with one straight away and on asphault - Thanks
capricess is offline   Reply With Quote
Old 01-16-2003, 08:42 AM   #2
newracer's Avatar
R/C Tech Charter Subscriber
it will probably fit in the car but 2speeds are not legal in most racing situations, unless your local track allows them
newracer is offline   Reply With Quote
Old 01-16-2003, 08:59 AM   #3
our local races allow them - I was just wondering would this be better since the track I race on is a tight curvy track.
Old 01-16-2003, 04:55 PM   #4
newracer's Avatar
for electric I don't think it would help unless the track had both a very tight section and a very open section or really long straight
Old 01-16-2003, 05:00 PM   #5
Where is it available and how much is it?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 01-16-2003, 05:54 PM   #6
Tom
Tom's Avatar
i remember when u could by a two speed kit for hpi mini, rs4 1-2 and mt. it looked just like a nitro one.
however i think eletric do not need two speed
Tom is offline   Reply With Quote
Old 01-17-2003, 12:27 AM   #7
That would be cool, however I don't think it would be very beneficial except for drag racing applications. Electric motors spool up so quickly that when geared properly there is very little time between 0 and full speed....... The problem the RS4 2-speeds had was that 1st gear was slightly undergeared and 2nd was dramatically overgeared.... This little booger isn't that way cause you place the pinion on the output shaft and 2nd is 1:1 so you slightly overgear and 1st speed is severely undergeared..... This would work better on high RPM motors with little torque. High torque/low RPM motors may never have enough to get teh cluch to engage.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-17-2003, 01:06 AM   #8
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
hm.. imho even if u can get those kind of speeds....... u cannot control or handle the car....... try 9 turn with 4.5:1 FDR ... think u get the idea ....
imataquito is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Kyosho 2 Speed Trans NEW lecronical Australia For Sale/Trade 0 08-15-2007 02:32 AM
2 speed Trans Help ZondaC12 Rookie Zone 4 01-24-2003 01:26 PM
2 speed Trans Help ZondaC12 Nitro On-Road 3 01-13-2003 07:03 PM
