Old 11-06-2006, 09:06 AM   #106
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by CRASH
Something does not sound right. Please give Joe Ford a call at Castle Creations
913-390-6939 ext 119 or via e-mail [email protected]
Later,
Follow Crash's advice, he knows his stuff.
Who knows, you may get him on the phone!!
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 11-07-2006, 09:53 PM   #107
No at this time you can not run a sensored motor on the Mamba Max. This is a software upgrade being worked on and should be available shortly.
this is mainley because off the weak magnets novak and others use right ???
in theorie the novak 3.5 should run fine because it has a sintered rotor ....
duhh is offline   Reply With Quote
Old 11-07-2006, 10:06 PM   #108
adamge's Avatar
I phoned in today and spoke with Joe. He was primarily thinking interference with the receiver is causing the hesitations. He did mention connectors, though, and that got me realizing that I had done a quick and dirty job when I shortened the ESC's motor wires and reinstalled the 4mm female bullets. I re-did them tonight, well this time, and I'll try it again this weekend.
-Adam
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 11-07-2006, 11:11 PM   #109
CRASH's Avatar
Trader Rating: 26 (100%+)
It has nothing to do with the magnets. It has to due with the design of the Novak motor. At this time the Mamba just does not work with the Novak motors. This should be an available software upgrade in the near future.
Later,
CRASH is offline   Reply With Quote
Old 11-10-2006, 11:35 PM   #110
Joe Ford's Avatar
Send a message via AIM to Joe Ford
Let me know what you find Adam...
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline   Reply With Quote
Old 11-10-2006, 11:39 PM   #111
CRASH's Avatar
Hey Joe, glad you finally made it over here.
Later,
Tony
Old 11-11-2006, 12:00 AM   #112
Joe Ford's Avatar
Yeah...just got done writing an article, and remembered you had mentioned this place so I figured I'd drop by. Glad to be here.
Joe Ford
Product Specialist
Castle Creations
Old 11-11-2006, 02:26 AM   #113
-Adam
I had the exact same thing happen to me tonight. I will try to shorten the ESC wires to see if this helps.
Jody
JoeRocket is offline   Reply With Quote
Old 11-11-2006, 02:30 AM   #114
I ran my 5700 Mamba Max this weekend in a T2'007. I had serious problems with the ESC losing sync/position. This occurred both after slowing down or coasting and then hitting the throttle, as well as from a stop. I tried various pinion/spur mesh tightnesses.
Has this happened to anyone? I'm close to calling Castle and then sending it back for warranty. It is not race-able like this.
Wires are factory length, connectors haven't been touched (factory installed).
-Adam
Sorry, This is the quote that I meant to grab!
Old 11-11-2006, 06:13 AM   #115
joe,
I have an HPI 10g wide pan car. With Novak 4.5 motor, this thing really rocks. Super fast at the 100m straight line.
Unfortunately, it went thermal shutdown everytime the track temperature was high. I am desperately looking for a replacement.
What do you think of having 7700 powering my wide pan car?
azmio is offline   Reply With Quote
Old 11-11-2006, 08:00 AM   #116
CRASH's Avatar
A Mamba Max 7700 system in a 1/10th scale pan car, all I can say is hold on tight, it is going to be a SUPER SONIC MISSLE!!!!
Later,
Old 11-11-2006, 08:04 AM   #117
CRASH's Avatar
There is also a new thread in company discussions for questions, comments and suggestions.
Castle Creations
Thanks,
Old 11-11-2006, 01:33 PM   #118
Originally Posted by azmio
joe,
I need some more time to set the Max up properly. So far it doesn't look like you need to worry about thermal shut downs. The software for the Max is awesome. Very quick and easy to use.
Old 11-11-2006, 08:59 PM   #119
Joe Ford's Avatar
Basically, unless you're geared completely wrong you shouldn't have any thermal shutdowns.
Azmio...that thing is gonna be nuts. If you use 4 NiMH cells, disable the BEC and use a receiver plug jumper from the ESC side of the battery connection directly into the receiver. This will keep you from losing signal at the end of the battery pack. 5 cells and up, no worries about disabling the BEC. 2s lipo would be INSANE!
Joe Ford
Product Specialist
Castle Creations
Old 11-12-2006, 01:30 AM   #120
joe ford,
Yeah, that's what I thought too. Unfortunately, here in malaysia, track temperature goes up as high as 54 degree C or 100 over farenheit. Regardless of how we gear our TC cars (10.5 and above for 4.5), thing will still go thermal shutdown. Things will be better in the evening and GTB with 4.5 will perform flawlessly.
Furthermore, with the high thermal load, 3.5 and 4.5 BL have very short life. So I guess the problem that we have are combination of high ambient temperature, high surface temperature, high voltage LIPO battery and high speed track with lots of heavy braking, hairpins and 100m straight line.
I am now thinking about buying 7700 mamba max. Hope that the bearing and the rotor are up to the challenge.
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 05:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 04:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 05:48 PM
