Old 07-24-2006, 04:21 PM   #61
I'm curious, how does cc claim to have timing advance, if their motor is sensorless?
Also, has anyone ever tried putting a sensor on their motor?- ie: a hall effect, or an optical encoder- and using a microcontroller to manipulate your input?
I was thinking a hall effect sensor with simple velocity linearization would be quite easy, and give better low end speed. However, something more complex, like a high resolution optical encoder, and a more complex program would give you the benefits of mamba's software/power, and the efficiency and total control of a novak sensored.
iamscottym is offline   Reply With Quote
Old 07-24-2006, 04:26 PM   #62
jaz
Low end speed with the Mamba Max is already fine. You can also adjust the throttle curve within the software to tweak it to just your style.
jaz is offline   Reply With Quote
Old 07-24-2006, 04:29 PM   #63
Mike Haynes's Avatar
The 5700 is the system to put in most stuff, it is plenty fast for fun, wil give great runtime, and isn't quite as hard on batteries / drivline components.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 07-25-2006, 12:39 AM   #64
Originally Posted by iamscottym
Any chance mamba's developing a sensored version?
I doubt it - in Castle creations eyes this would be a leap backwards.
I have adjusted timing in my Mamba 25 before and it does makes a difference. I assume they use the back emf from the motor power leads as their "sensor".
If I put my mamba 25 on a slop so it rolls backwards (with no throttle input) and then I hit forward throttle the ESC puts the motor into brake mode first until it comes to a stop then accelerates so its got to be doing something
au_Nightmare is offline   Reply With Quote
Old 07-25-2006, 07:00 AM   #65
then that would count as sensored wouldnt it? sensors are typically either hall effect'rpm' counter style, optical encoder stepper motor style, or it uses back emf.
Old 07-25-2006, 07:38 AM   #66
Sensored - you mechanicaly monitor the position and speed of the rotor in respect to the windings
Sensorless - you watch the information coming back through the motor wires to ascertain the position of the rotor.
Sensorless, when done right, is better than sensored, when done wrong, is a real mare.
DA_cookie_monst is offline   Reply With Quote
Old 09-27-2006, 06:28 PM   #67
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I just oredered the 5700 system for two reasons.
1) It closely mirrors the standard 19T's I run as per RPM...
2) I foudn out the Mamba Maw is Brushed/Brushless so you can practice with the brushless to get your setup dialed....then pop in the brushed for quals and mains.... Until they have a brushless class...
Man what a deal for $212.00 and the ESC is only slightly larger than a spektrum receiver........DIALED.....
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-04-2006, 12:36 AM   #68
Speed Demon's Avatar
I love the MAMBA MAXX..
the only I wish from Castle is:
1. Smaller size ESC
2. Castle Link software for Pocket PC. it's a hassle to bring a laptop to the track.
Other than that, all is awesome!!!!
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 10-04-2006, 08:58 AM   #69
Francis M.'s Avatar
Can some one post a pic of the system mounted and wired? I want to shorten the wires on mine and just want to see some clean wiring.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 10-04-2006, 09:20 AM   #70
timmay70's Avatar
Mike Haynes, do you use the Mamba esc in touring (competitively), or are you using a dedicated brushed controller? Have you used the Mamba in brushed mode, and how does it perform as a brushed controller? If I use brushed motors mostly, is it worth getting the Mamba, or sticking with a dedicated brushed esc?
thanks.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-04-2006, 09:30 AM   #71
I have not been running the complete setup as it was not legal at most of the big races this year.
I have used the esc in brushed mode, and it feels fine to me. I typically run a QC2 since it is smaller and fits in my 12th scale much better. The speedo will work just fine for brushed, and dosn't get as warm as my lrp, but it is bigger, and you do need to use a different wire setup. For touring car it is great for practice and i have run it for club races when i put a brushed back in after practicing BL....seems the 4600 geared rather hard runs very similar to a good 19 turn. I usually use the 5700 to practice mod, its feels similar to an 8-9 turn so it is plenty. The 7700 is a bit much for most indoor tracks.
If you want versatility and have a touring car, you can't go wrong. It would not be the best idea for 12th scale though.
Old 10-04-2006, 09:38 AM   #72
adamge's Avatar
Mike, can the Mamba Max 4600, properly and reasonably (i.e. gears available and fit in a TC chassis) geared, keep up with low turn brushed motors and other brushless setups that one might go up against in mod?
It says 4600 in my sig, but it's on backorder and can be changed.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-04-2006, 09:46 AM   #73
If you want a raceworthy mod equivelent, get the 5700...if you want ballistic speed ala Novak 3.5 ish, you will want the 7700.
Old 10-04-2006, 10:08 AM   #74
timmay70's Avatar
Thanks Mike. I was looking to replace the QC2 with something that is easy to program with the idea of trying different things that the CC esc offers. I think I will look somewhere else, as I do primarily stock in on-road. However, for off road I may have to keep an eye on this system. Thanks, tim.
ROAR #105242
Old 10-04-2006, 02:03 PM   #75
Trader Rating: 30 (100%+)
I have a Novak 5.5R and I was deciding whether to buy the 5700 or the 7700. Is the 5700 similar to the 5.5R and is it faster?
wrxnfx is offline   Reply With Quote
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 05:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 04:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 05:48 PM
