Old 10-12-2007, 02:34 AM   #256
Mooshu Beef's Avatar
so to run brushless systems, is it necessary for high mAh batteries, or LiPo? It seems that these systems would demand a lot from batteries--more so than a regular ESC.
Wow... 50mph... I can't imagine my car going that fast... well at least the 1/10 one.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 10-12-2007, 10:56 AM   #257
Trader Rating: 30 (100%+)
If you run the 7700, you will need to run high end batteries, wires, connectors, etc. Otherwise, you will probably have problems with cogging and possible other issues including possible battery damage. Yes, these Mambas can draw a lot of power. A friend of mine literally melted two cheap battery packs with a 5400 by over gearing his truggy. No damage done to the Mamba, though.
wrxnfx is offline   Reply With Quote
Old 10-12-2007, 12:41 PM   #258
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Drift Demon View Post
Very very impressed with my MM/Vortex 7.5 combo!!
Does that Vortex come with sintered rotor and replaceable ceramic bearings??
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-12-2007, 04:45 PM   #259
sinistered yes ceramic bearings not sure
C_Suzuki is offline   Reply With Quote
Old 10-12-2007, 06:37 PM   #260
I just realized that the picture was of a TT-01.
How does the drivetrain handle under that torque? Also are you using the tamiya pinions? I know the spurs are specifically made for the TT-01 by Tamiya, but I was curious about your pinion. If it is the tamiya pinion, do you find that you need to replace it often, since the aluminum they use is rather soft?
Wow I am rather envious of these setups...
Old 10-12-2007, 07:31 PM   #261
Verndog - sintered rotor yes. Im not too sure about ceramic bearings either. but looking at a speedpassion ad, they have ceramic bearings as an upgrade...
Mooshu Beef - When i first got the Mamba Max i had the 5700 motor, and the first run obliverated the tamiya pinion gear. The next pinion gear i used was a Tobee craft alloy, it held up fairly good, but also stripped with a 4600 motor strapped to it. with the vortex, im now using robinson racing metric steel pinion, after 3 x 30min runs, ive just inspected the pinion and its holding up very very well!!
Drift Demon is offline   Reply With Quote
Old 10-14-2007, 05:31 PM   #262
i have a small problem.I'm running the 5700kv system and every time the car move off it gives a slight left turn. dose any one know how to remedy that problem?
snail run is offline   Reply With Quote
Old 10-14-2007, 06:36 PM   #263
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Make sure your cars weight is balanced from side to side. If it pills to the left it is possible that the car weighs a little more on that side.
ST Racing Concepts (STRC)
Old 10-15-2007, 05:15 PM   #264
that has nothing to do wit it. i held the car in my hand and squeezed the throttle and the steering servo moves to turn left
Old 10-15-2007, 05:29 PM   #265
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
guys if anyone is looking for a 4600 motor nib never run let me know
twistedone is offline   Reply With Quote
Old 10-15-2007, 06:03 PM   #266
wyd
Tech Legend
wyd's Avatar
Ok then have you tried another servo to see if it does the same thing? If so then next step I would try if it iwas me would be another receiver. Even though it works I would just like to find out why the servo turns left when you hit the throttle.
Old 10-15-2007, 06:34 PM   #267
Scrad's Avatar
Trader Rating: 15 (100%+)
I was borrowing a buddies KO servo and it would do the same thing with my KO speedo if I ran a 19t or any mod motor. I didn't do it with a stock motor. When I fixed my JR servo it worked fine. You might want to put a Spektrum capacitor in the battery slot. I think the servo is loosing power for a split second because of the high pull on the batteries from the motor.
Scrad is offline   Reply With Quote
Old 10-16-2007, 06:23 AM   #268
bighurt98's Avatar
Default Wiring??
She's a little dusty. My Vortex arrived the other day, i have hardwired it to the esc. Timing on motor is 0 (center). Settings on Mamba Max are default except for a few, so ill have to post an image later. I used mooony's wiring setup (red wire -> C, black wire -> B, white wire -> A). Using 8.35FDR & Orion/Peak 3200 lipos & Spektrum DX2.0.
After a 20min drift run. Hearing the majority of mm/vortex ppl having stuttering & cogging issues, i was certain this was going to happen to me. For me though, no stuttering at all, ran as smooth as a babies bum. no cogging at low/mid/high throttle. I kept feathering the throttle to see if it would, this thing basically ran flawlessy!! Very very impressed with my MM/Vortex 7.5 combo!!
DirtDemon, You have PM!
How can I be wired different than you and still race, but had no top speed, ok punch??? I changed gearing for top speed, I know accel will decrease, but system shutdown twice with gearing going from 4.71 to 4.5 OK then 4.4, shutdown?? Still, I was hammered on straight and short shoots!!
A Red
B White
C Black
Dirt Demon wiring:
A White
B Black
C Red
Same ESC, so wires are the same on ESC!
Please give some understanding!!
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 10-16-2007, 07:21 AM   #269
mooony's Avatar
A Red
B White
C Black
Dirt Demon wiring:
A White
B Black
C Red
You can place the wires anyway you want. You only need to check that the motor is turning in the right direction. if not, you need to swap just 2 wires around.
Ronald
mooony is offline   Reply With Quote
Old 10-20-2007, 03:37 PM   #270
bighurt98's Avatar
Default Combination ESC/motor problem??
This aplication is for On-Road Open Stock with 4800 Orion Lipo!
Ok! I got my shutdown issue fixed and now went about trying to get some speed. Geared down from 4.4 to 4.12 and the car still has no top speed.
Gearing: (86 spur / 47 pinion) X FDR 2.25 = 4.117
ESC: Mamba Max
Motor: Orion Vortex 13.5
Now my question. I have made adjustments to ESC for cogging. Some say they have none, I have some!
By changing the punch to 60% from 0% to help control cogging, could I be loosing my speed from that?
Or, adjusting timing of motor in ESC profile from normal to high for more acceleration cause the loss of speed? Motor temps today were higher, but not past 160 degrees.
Suggestion please!
Thanks!
Desoto Racing
Team Gravity
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 05:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 04:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 05:48 PM
