Old 06-29-2006, 11:42 PM   #1
coons88's Avatar
Send a message via MSN to coons88
Default Ko Propo 2343
I am running a 2343 with my spektrum, and not enough power is being deliverd to te servo, causing it to pulse back and forth. I was planning to get some diodes so I could run the servo straight off the battery. The guy in the shop said he has had quite alot of experiance with 6v servos and said that they can quite easily run on up to 9v.
What do you think about that? Running the servo straight off the battery (about 8.5v) without any capacitors or diodes. Will it be ok, or could I blow the servo?
Associated TC6.1 | Hobbywing V3 | LRP X12 | Spektrum | Futaba | Reedy
coons88 is offline   Reply With Quote
Old 06-29-2006, 11:57 PM   #2
Drewdc90's Avatar
It would probably be better just to plug a cap into the receiver.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 06-30-2006, 12:04 AM   #3
coons88's Avatar
This is as a back up plan incase the capacitor doesn't work. I tried a capacitor today, it worked for about 20secs, then you had ot wait for like 10secs for it to charge up again. I don't think it was the correct rating though. I will buy a 4700uf 10v cap tomorrow and try it out.
Old 06-30-2006, 12:24 AM   #4
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
The more important question, what speedo are you running? If you're running an LRP or a KO, they don't have a 6v BEC. The LRP's are only 5v and the KO is 4.5. You could try a few things. Run the + servo wire directly to the battery, which will void your warranty in a heartbeat, run a RX pack or build a power booster circuit that will pump the voltage to the rx up to 6v.
RcCzarOfOld is offline   Reply With Quote
Old 06-30-2006, 12:35 AM   #5
coons88's Avatar
I am running a Tekin G-11pro. It puts out 6v. Servo as been working fine on my PCM receiver. I tested both receivers, the PCM receiver put out 5.97v, spektrum receiver put out 5.66v
The options I was considering:
1. Run a capacitor
2. Run the servo off the spare wire from the G-11pro that is straight from the battery.
3. Run a receiver pack (but can't really fit it in my car, and adds unwanted weight, plus it just looks ugly)
First I will try a capacitor, if that fails I will try running straight off the battery, if all that fails I guess I will have ot resort to a receiver pack or buy a new servo.
Old 06-30-2006, 01:23 AM   #6
Drewdc90's Avatar
If you get the right cap you shouldn't have a problem.
Old 06-30-2006, 06:29 AM   #7
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Also speaking with Robert (a.k.a. KO Staff) Yes you can run off the battery but you will void the warrentee and by doing that to your servo you will put alot more wear on your servo motor and will greatly shorten its life.
Most Off Road Pro's do this to up the torque and speed of servos, they use 6 cells receiver packs or lipo without regulators. But they are spouncered and don't have to pay for their servos like us mear mortals.
Hope that helps,
And yes I had the same problem with my 2343, if you get the 4700 capasitor you should be fine.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-30-2006, 06:40 AM   #8
schmelme's Avatar
i run a 2343 and a 2344 in my 1/8 scale with the spektrum receiver with no problems. I assume this is an amp draw issue with bec in the speedo.
schmelme is offline   Reply With Quote
Old 06-30-2006, 08:03 AM   #9
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I have spektrum (old version of the 2343 for steering) and KO in my TNX and it works fine...like Schmelme said, it's more likely the speed control.
On the motor versus voltage thing...first, running higher voltage doesn't wear the motor faster, if anything, it's the other way around. I can't tell you how the electronics on the circuit board will handle it, but if you go up in voltage, the motor will be under less stress/load/heat and draw less current.
Second, I've run 6-cell reciever packs (7.2V park flyer stuff) in my TNX forever...not a problem at all.
Turbo Joe is offline   Reply With Quote
Old 06-30-2006, 08:12 PM   #10
coons88's Avatar
Thanks guys, just installed a 4700uf 16v cap, (10v was out of stock, but 16v is basically the same) and it works perfectly!
ko propo 2343 pinggoy R/C Items: For Sale/Trade 6 08-10-2006 10:29 PM
KO Propo 2343 Servo *Topher* R/C Items: For Sale/Trade 2 06-22-2006 03:56 PM
NIB Ko Propo PDS-2343 FET loosenut R/C Items: For Sale/Trade 6 08-10-2005 10:50 PM
TC4, B4, KO VFS Pro, KO Propo 2343, Greg Amendola R/C Items: For Sale/Trade 43 04-27-2005 08:44 PM
KO Propo 2343 Servo *Never Used* scoobydo R/C Items: For Sale/Trade 3 04-14-2005 06:36 PM
