Old 06-28-2006, 09:17 PM   #1
Default MM Zero-V
Hi guys what does it mean when the lights goes out on the Zero-V? All the lights goes off like in just 5 minutes!
A_380 is offline   Reply With Quote
Old 06-28-2006, 09:29 PM   #2
what batts are you using? when the lights go out it means the batts are in .9v/cell
HTH
skamolly is offline   Reply With Quote
Old 06-28-2006, 10:59 PM   #3
Thanks for reply dude. I'm using GP3300. So leaving it for 3 days will bring the batt to 0V, eh?
Old 06-29-2006, 12:11 AM   #4
Nicadrauspro4's Avatar
Leaving your batts for three days on the Zero-V helps condition your batts too. But discharge doesn't really take three days to do it. As long as all the lights are off, then it should be ready for charging already. Just cool the batts first after discharge or before charging it again. Another tip on discharging your batts with the Zero-V, place it beside a fan to keep the temperature low while discharging.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 06-29-2006, 01:25 AM   #5
RCRookie_KR's Avatar
Default 0.4V
The batts are in about 0.4v/cell , not 0.9v/cell.
RCRookie_KR is offline   Reply With Quote
