SHOCK SHAFTS/TAMIYA
You can't get half an inch more travel, the standard shafts already go the full length of the shock body.
You could get more length by fitting a longer shock end, the HPI ones may be a shade longer, in fact any 3mm long ball end will do the trick. Tamiya's CVA dampers come with long ends as well as the standard short ones.
