Old 06-27-2006, 01:23 PM   #1
Default Old NiCD batteries
Hi I have an old battery pack thats been laying around for a few years. When I put it in my car and try to run the car, it tweaks out and acts like its about to die. Maybe its not charging or something but it should charge since I used 2 different chargers and the same thing happens. Is this happening because the pack was unused for so long and lost permanent voltage and is there anything I can do about it like use a battery balancer or anything? Thanks.
viperx07 is offline   Reply With Quote
Old 06-27-2006, 01:33 PM   #2
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Most likely sat for too long.
EricO3 is offline   Reply With Quote
Old 06-27-2006, 01:43 PM   #3
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Hahahaha.... I used a matched Sanyo 1400 pack for my T-Maxx EZ start... Still holds a charge after 15 years....
I have around 15-20 1200-1700 packs that I should just ditch, I do wonder if they'll take a charge though....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 06-27-2006, 02:23 PM   #4
Send a message via AIM to Deznuts05
if they are built in a side by side config you could discharge them and tray it. then charge them at 3amps that should wake them up.
Deznuts05 is offline   Reply With Quote
Old 06-27-2006, 08:03 PM   #5
bring nicads to zero volt then charge.
skamolly is offline   Reply With Quote
Old 06-27-2006, 08:27 PM   #6
Just dump those away....I tried to wake up my 1700s matched cells from yester years....To no luck...Then I thought,its time for them to go to a better place...
Ben.C is offline   Reply With Quote
Old 06-27-2006, 09:02 PM   #7
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
Im actually expiriencing this now to.. here is what i did.. I have a ton of old packs, and im building a power base for my lathe.. im going to use a 4 cell pack to power it.. i grabbed a pack and it would not charge.. Basically i trickle charged it for a bit to forc some charge in it.. thn i dumped it and trayed it.. then charged at 4 amps and discharged it a few times.. you basically have to re train the pack to take a charge.. the pack will never haver any performance again but it could still run..
burbs is offline   Reply With Quote
Old 06-28-2006, 04:27 AM   #8
Frank McKinney's Avatar
Just wanted to mention that instead of putting those old cells in the trash and having them go to a landfill (bad mojo), see if you can drop them off somewhere for recycling: http://www.rbrc.org/call2recycle/dropoff/index.php
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 06-28-2006, 06:56 AM   #9
Send a message via AIM to A-Ko
Nicads don't like sitting around long with no use. If they sit they should be dead-shorted from tray then jumpered. All mine are in that state. If they crystalize around the positive they are junk.
As far as recyclers take them to Radio Shack they accept any and all batteries. I took them a bag-full about 6 months ago.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 06-29-2006, 04:20 PM   #10
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
Ditto, on the Radio Shack answer.
I been playing wif RC cars for better than 20 years and have also tried to pump up some older cells. They may look good on a discharger but when actually trying them in a car/buggy/truck..., They will flop!
I have even bot some new ones on Ebay that charge up just fine but they will never be used in one of My vehicles, cuz they just simply SUK!
Even for just bashing, it wood be best to just git new ones. They ain't that expensive and U'll waste more time and energy trying to pump-up those older Packs.
PlainOleDave is offline   Reply With Quote
Old 06-29-2006, 04:45 PM   #11
EricO3's Avatar
Git R' Done!
question about chargers and Nimh/NiCd batteries. existenz Radio and Electronics 0 11-03-2007 08:39 AM
for sale batteries(nimh&nicd), motor(orions&novak), heli, etc....<<<<w/PICS>>>> hpipro4 R/C Items: For Sale/Trade 37 10-19-2007 08:06 PM
Questions about NiMH/NiCD Batteries rcnewb2004 Electric On-Road 2 10-10-2007 01:11 AM
WTB: NiCd Batteries chadlogan R/C Items: Wanted to Buy 16 03-08-2005 03:45 PM
Best batteries for bashing Nicd or Nimh pecor Electric On-Road 8 10-04-2003 04:28 PM
