Old 06-27-2006, 11:42 AM   #1
Default Esc??
Hi im after a little help, I know you guys Know your stuff so i thought id give you the chane to shine and shower me with your knowledge.
I have a stock TL01 and have just brought a venom 19x2 modified motor and wrap around heatsink!!
Thing is i have a stoch ESC and was told by one company that the stock ESC would handle my newly purchased beast!!
On the other hand i have someone saying i have to fit a new ESC because mine will go pop!!
any ideas
creamsodauk is offline   Reply With Quote
Old 06-27-2006, 12:47 PM   #2
buzz06's Avatar
Send a message via MSN to buzz06
buy one that has a higher motor limit than 19t
buzz06 is offline   Reply With Quote
Old 06-27-2006, 01:14 PM   #3
If yours is one of the Expert Built RTR TL01's then yes you will need a new speed controller. The mechanical one will not handle that motor. The plus side is that you will loose alot of weight and the car will be faster.
-Jason
juggalorc is offline   Reply With Quote
Old 06-27-2006, 04:08 PM   #4
Talking
what about fitting it??? how is this done?? and will i have to change or programe the controller, or am i way off their lol.
what should i go for then a 15t esc or somthing
Old 06-27-2006, 08:42 PM   #5
I think you should go to Ebay and look for a decent 2nd hand Novak GT7 ESC (it has no motor limit and was a top novak ESC till a few yrs ago)...
Ben.C is offline   Reply With Quote
Old 06-28-2006, 11:19 PM   #6
rcdy's Avatar
i dont think a TL01 can handle that motor, better check the motor gearing first. try upgrading a ball bearings and speed tuned gear set hope it works.
TeamXray, TeamAssociated, Esky, Tamiya
rcdy is offline   Reply With Quote
Old 06-28-2006, 11:37 PM   #7
ford_racing's Avatar
Send a message via MSN to ford_racing
If you are going for a low turn motor keep the standard gears in there, the speed tuned ones will kill the motor on the first run
bearings are a must have upgrade
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 06-29-2006, 07:10 AM   #8
If you do have a mechanical speed controller you will have to remove the servo, speed contoller and resistor.
As far as a ESC I would recommend the Novak GTS. It's pretty much the same as their GTX but has a 12 turn motor limit. Most ESC's just have one button to program them to your radio.
Hope this helps
-Jason
Old 06-29-2006, 05:13 PM   #9
Red face let me see??
OK the car is stock and the motor i brought is a 19x2 so its not a crazy motor(its a venom one).
i brought a 15 turn limit esc with forward break and reverse (couldnet live without reverse) i want to get the barrings kit but i have the manual but it looks a fair job stripping down the car and replacing them. any tips, (and are the bearings on ebay that cost under a tenner GBP any good their metal)
as for the gears i want acceleration for drifting and outrunning my mates car not so much top end so will the standard bearrings be ok???
the car came running with a TECHNIPLUS controller and the esc supposidly will be fine with that?? is that true??
this is my esc i brought any ideas??
Mtroniks Sonik4 RV15 ESC (Fwd/Brake/Reverse,15t Limit)
also what other hop up will improve power that is fairly cheap and easy to install??
cheers for the help kris
(this is my car the shell has had a beating but the rims look minted 8)
Old 06-29-2006, 05:21 PM   #10
rcracer0229's Avatar
Send a message via AIM to rcracer0229 Send a message via MSN to rcracer0229
Just find a no motor limt one on ebay like a duratrax one for that tlo1
rcracer0229 is offline   Reply With Quote
Old 06-29-2006, 05:37 PM   #11
Talking
lol the esc i mentioned i have brought. so will it be ok so far evryone i have spoke to says YES!
just wanted to know if this esc and my controller are ok and that i wouldnet have to upgrade the gears!
cheers kris
Old 07-03-2006, 01:04 PM   #12
TryHard's Avatar
the bearing kit you mention... if its the Walawala store ones... they'll be fine Just for the time being, don't take the greese out. It's a comon racers trick for a freer running car, but it can reduce the life of the bearing.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 07-27-2006, 01:28 AM   #13
REALLY? I ALSO HAVE A TL01 WITH A 15TURN MOTOR WITH STOCK GEARING AND BEARINGS. IS THIS BAD? WHAT SHOULD I DO FAST? ALSO, CAS IS NOT RUNNING PROPERLY AS MY FRIENDS 17TURN IS FASTER THEN MY 15TURN?
saemynamebitch is offline   Reply With Quote
