Old 06-27-2006, 09:15 AM   #1
revo61's Avatar
Trader Rating: 18 (95%+)
Default Smoother TC4 Ball Diffs
I was wondering if anyone has tried Acer's Ceramic Nitride Pro Series Differential Balls in there TC4? I was thinking of using them with white lithium grease on in my ball diffs. Do you think this will make the diffs smoother?
revo61 is offline   Reply With Quote
Old 06-27-2006, 10:25 AM   #2
timmay70's Avatar
Sand the diff rings with fine grit emery cloth, and build per AE's instructions. AE diffs always build up glass smooth. If they aren't smooth after that, replace the thrust bearing components. Use the black grease on the thrust bearing and the translucent lube on the diff balls. I have never had a problem getting glass smooth AE diffs.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 06-27-2006, 11:02 AM   #3
JayL's Avatar
I have found the thrust bearing has a larger effect on the 'smoothness' of a diff than the balls.
Make sure you start with the diff loose and work up to where is doesn't slip, having it too tight at the beginning adds to the nonsmoothness
I do use the acer pro balls in my diff as it seems to last longer but is isnt any smoother than normal balls...
JayL is offline   Reply With Quote
Old 06-27-2006, 12:56 PM   #4
revo61's Avatar
They are pretty smooth but I want them like a xray, smooth.
Old 06-27-2006, 01:15 PM   #5
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Just takes practice to get them smooth, consistently.
EricO3 is offline   Reply With Quote
Old 06-28-2006, 08:21 AM   #6
revo61's Avatar
Anyone know if the Xray thrust bearing will fit the TC4?
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 11:48 AM
Ball Diffs HalfOfEight Rookie Zone 5 05-09-2007 06:48 PM
Ball Diffs EVADER RACER Australian Racing 4 02-16-2004 03:16 AM
Ball Diffs EVADER RACER Electric Off-Road 0 02-09-2004 04:35 PM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
