Old 06-26-2006, 09:40 AM   #1
Mike S's Avatar
Default What car is better?
I'm looking for a car with the smoothest transmission with the least amount of friction. I want the fastest possible car to use in 540.
I would prefer a belt drive car.
Mike S is offline   Reply With Quote
Old 06-26-2006, 09:42 AM   #2
I have a Schumacher Mi2 EC and the drivetran is very smooth and free.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-26-2006, 10:06 AM   #3
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Whichever one you can get parts for the easiest... They are all good...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 06-26-2006, 10:13 AM   #4
Mike S's Avatar
I can get parts for most cars easily
Old 06-26-2006, 10:25 AM   #5
The best car is the one you have the most fun with.
Jon3 is offline   Reply With Quote
Old 06-26-2006, 10:30 AM   #6
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Juggalo's would go with a T2
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 06-26-2006, 10:39 AM   #7
Mike S's Avatar
I have to get a T2 now
Old 06-26-2006, 10:41 AM   #8
timmay70's Avatar
FT TC4 :P
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 06-26-2006, 11:23 AM   #9
X2
X2's Avatar
T2 is awsome chassis, you won't be dissapointed.
X2 is offline   Reply With Quote
Old 06-26-2006, 11:26 AM   #10
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Originally Posted by timmay70
FT TC4 :P
A ton of guys out here swear by this car for spec 540 out here.
JohnMatrix is offline   Reply With Quote
Old 06-27-2006, 05:10 AM   #11
BrainTeased's Avatar
yea i had an evo 4 runing same gear ratio if not a tooth taller than a FT TC4 and same packs 1.2 volts in 540 pro (silver cans with any gearing) and he pulls away on the straights!!! weird as!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 06-27-2006, 05:51 AM   #12
Smile
The Yokomo BD you have should have a smooth and free drive train for 540. I currently run a BD fitted with a grey 540 motor in Sydney, using double one way's and this is smooth as.
All cars can have smooth and free drive trains provided care is taken on building. Maintaining the free drive train is the key. This is dependant on periodic maintenance.
The BD hauls when using a 78 Spur and 34 pinion. This factor is also dependant on Batteries, type of speed controller and how smooth the driver is on the throttle and lastly setup.
Later
Calvin.
caltech1 is offline   Reply With Quote
Old 06-27-2006, 06:10 AM   #13
ChrisP's Avatar
Working to get yourself as smooth as possible to maintain corner speed will be your secret to being fast.
ChrisP is offline   Reply With Quote
Old 06-27-2006, 06:26 AM   #14
Send a message via AIM to RcCzarOfOld Send a message via MSN to RcCzarOfOld Send a message via Yahoo to RcCzarOfOld
If you want a belt drive car and you need it to be as free as possible, I'd reccomend a JRX-S. Of coarse, after you get past the incredible freeness of the drivetrain, you realize the rest of the car is a piece of crap... But in a 540 class, you'll be going slow enough that I don't think you'd have to worry about breaking it every time you put it on the track...
RcCzarOfOld is offline   Reply With Quote
Old 06-27-2006, 01:56 PM   #15
Baja's Avatar
2wd something like a F103 or a 1/12 or 1/10 pan car. Smooth drive train.
Baja is offline   Reply With Quote
