Old 01-14-2003, 04:14 PM   #1
Send a message via AIM to lilshortyc3
Default RPM ball cups
Is it true dat RPM ball cups aren't as good as the Associated ball cups. I heard dat they fall of much easier then the Associated ones.
lilshortyc3 is offline   Reply With Quote
Old 01-14-2003, 05:57 PM   #2
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Personally, I like the RPM ballcups. I never broke one yet and I have only popped 2 off in mod crashes. Other than that they are awesome. You also have your choice of colors.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-14-2003, 07:30 PM   #3
skibum989's Avatar
RPM ballcups are the way man.... they stay on better, have less play, and don't break as easily. Plus, like Trinityracinnut said, they look cool in a choice of different colors.
Ryan Robison
SeattleRCRacers.com - come race with us!
skibum989 is offline   Reply With Quote
Old 01-14-2003, 11:09 PM   #4
RPM or Losi are some of the best associated cups are lighter, but Schumacher cups and ballstuds are the best....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-15-2003, 10:57 AM   #5
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Default Re: RPM ball cups
RMP ball cups are far superior to the AE ones. Just look at the construction. . .
compared to the AE ones that don't have the thick sidewalls. . .can't find a pic right now. . .
Oh well, you can at least see the RPM ones
Boomer is offline   Reply With Quote
Old 01-15-2003, 11:13 AM   #6
Claydoh's Avatar
Send a message via AIM to Claydoh
The only thing wrong with the rpms is with some wide rims, they rub the rims on the rear hubs. I just replaced those with the AE ones. None of them last forever though. I just replaced all mine. The more boards you hit, the more slop they develop.
Claydoh is offline   Reply With Quote
Old 01-15-2003, 12:18 PM   #7
popsracer's Avatar
Default RPM Ballcups
I've found that the RPM ballcups will outlast the Ballstuds many times. Especially Aluminum Ballstuds. The LOSI Ballcups and the new HPI Heavy Duty Ballcups are about the same as the RPM ones, so you have a few more choices.
popsracer is offline   Reply With Quote
Old 01-15-2003, 10:45 PM   #8
Trader Rating: 69 (100%+)
can i use rpm ball cups on a tamiya 414M? the turnbuckles have metric threads (3mm i think) and the ball connectors are 5mm. thanks for any info
marvi is offline   Reply With Quote
Old 01-15-2003, 11:04 PM   #9
Boomer's Avatar
You should be able to - ball cups aren't threaded, they're just plastic/nylon so you should be fine.
Old 01-15-2003, 11:13 PM   #10
thanks i need to replace the ones on my 414. they pop off easily. especially since i crash all the time
Old 01-15-2003, 11:14 PM   #11
I agree with Impact, the Schumacher ball cups and ball stud are about the best you are gonna get. I have had HPI, RPM, AE, and Losi ball cups pop off on me. I have never had a single Schumacher ball cups pop off. Maybe it is because they are harder than heck to pop onto the ball stud.
James Nguyen is offline   Reply With Quote
Old 01-17-2003, 08:52 PM   #12
i found some old rpm ballcups for a tc3, and they did fit the turnbuckles' thread of the 414. unfortunately, the ball cup wont fit, its too small
Old 01-17-2003, 10:27 PM   #13
Moderator
Are you sure they won't fit? the tighter the better
SMC Racing
Old 01-17-2003, 10:56 PM   #14
Marvi, tey can be forced onto the ballstud, however they will be so tight the suspension will be severelly bound up.......
Old 01-18-2003, 09:37 PM   #15
dtm
dtm's Avatar
Send a message via ICQ to dtm
Simply change to Yokomo or Kawada balls...they are 3mm threads compared to 4-40 of the AE. You will find that that fit fine..
dtm is offline   Reply With Quote
WTB RED 4/40 ball cups gene465 R/C Items: Wanted to Buy 3 11-13-2007 08:15 PM
Metric Ball Studs and Ball Cups for RB5 Sohlman113 Electric Off-Road 0 10-27-2007 09:23 AM
ball cups losidude01 Australia For Sale/Trade 2 04-18-2007 12:56 AM
Ball Cups sean Electric On-Road 4 09-27-2003 08:12 PM
How to pop ball cups over ball studs Switch Blade Electric On-Road 1 03-04-2003 05:38 AM
