Old 07-07-2006, 11:13 PM   #91
UFShadow - you are correct regarding 2WD based on Touring (T1R?) are muchmore forgiving than true pan car, IMO : 1. T1R have longer suspension stroke length > more suitable for bumpy track 2. Rubber tire (as seconday suspension) absorbs bump much better than foam
But TC suffer more drivetrain friction than DD car,
try to push pan car and belt TC with your finger on the floor (w/o motor and batt) then pan car will always go further
at least, using Touring Car tire (rubber + soft insert) should help pan car gain traction on imperfect asphalt,
What I have try with auldey and 10L3T :
- Indoor cement floor Both car with foam tires and > on-throttle traction and handling are easy and almost equal both car
- Outdoor smooth asphalt Auldey with touring tire sorex 40R + soft insert > far better on-power traction than 10L3t on foam
Faiz is offline   Reply With Quote
Old 07-08-2006, 07:09 PM   #92
tallyrc's Avatar
what shore foams were you running?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-09-2006, 08:12 PM   #93
jo90, no pan car part in my 2wd touring. just converted T1R evo2 xray car. Last to day, I was try my car using shadow motor. struggle to keep the racing line. But the speed look similar to 5 pot 1/10th nitro. Thats what I want. Tyre 37shore (rear) speedmine and 40 (front). Still under testing...
With SS5800 easy to control close to 7T brushed speed, but since 4wd can blow the throttle at 1/3 of the corner. I don't have advantage.
Shadow give the speed that I ask. At last pack, reduced throttle exp to -40%...looks better. Next testing...I will find tyre that more grip for rear tyre.
Anybody, How to calculate roll-out?
UFShadow is offline   Reply With Quote
Old 07-10-2006, 12:21 PM   #94
tallyrc's Avatar
performance: you need to get on the ball. this fella seems to have found what your looking for...
Old 07-10-2006, 07:55 PM   #95
My SPX3 Pro sold. This is a excellent car with good plastic material. Original tyre don't have enough traction as I like. This car very stable once you get enough traction.
Old 07-11-2006, 01:53 PM   #96
tallyrc's Avatar
shadow, did that car come with a body? also, does it use 1/10th scale tires or 1/12th scale tires? i wish i had the part number for the body...
Old 07-11-2006, 07:36 PM   #97
PerformanceRC's Avatar
That is the old SP3-X not the SP3-XT
Same cars different sizes
1/10 SP3 XT Touring Car
■ WIDTH : F-185mm/R-188mm
■ WHEEL BASE : 257mm
■ TREAD : F-161mm/R-164mm
■ WEIGHT : 1,300g(RUNNING WEIGHT)
1/10 SP3 X , SP3 X PRO
■Width..............230mm
■Wheel Base..............259mm
■Tread (F/R)..............180mm/179mm
1/12 SP3 EXTREME, LANCE, SP3 2
■Width..............172mm
■Wheel Base..............198mm
■Tread (F/R)..............132mm/137mm
■Weight..............863g(Approx, Battery Included)
1/10 SP3 MATIZ
■Tread (F/R)..............137mm
■Weight..............906g(Approx, Battery Included)
PerformanceRC is offline   Reply With Quote
Old 07-11-2006, 07:38 PM   #98
the SP3 Extreme ,Lance and Matiz are the only SP3 with factory body
Old 07-11-2006, 08:07 PM   #99
Kawahara 37 Front (28mm width) , 35 shore Rear (32 mm width)
Old 07-11-2006, 08:25 PM   #100
tallyrc's Avatar
no 200mm 1/10th scale bodies available?
Old 07-11-2006, 09:05 PM   #101
SP3 X pro using 1*10th tires with 230 GT body.
Old 07-11-2006, 09:24 PM   #102
200mm shells Not from Academy
Old 07-11-2006, 10:26 PM   #103
Trader Rating: 26 (96%+)
If you are looking to run rubber on a pan car then go invest in some buggy rims. The rims are actualy very similar in size to a pan car rears and you should be able to find a good tire for asphalt.
party_wagon is offline   Reply With Quote
Old 07-11-2006, 11:25 PM   #104
TEM
TEM's Avatar
Actually, if you want to run rubber tires, go find yourself some pan car to hex adaptors and you can run TC wheels/tires. Does anyone remember who makes them and where to get them?
TEM is offline   Reply With Quote
Old 07-12-2006, 02:46 AM   #105
Sedan or GTP?
GTP? Rcmart have some of them
wtb or wtt for an electric touring car CHAVAN30 R/C Items: Wanted to Buy 5 05-20-2008 10:26 AM
Looking to get into electric which touring kit?? NitroMaxx3.3 Electric On-Road 4 06-21-2007 11:33 PM
Electric touring car jonto100 Electric On-Road 11 08-22-2005 02:36 AM
1/10 electric touring RCNitroDude999 R/C Items: Wanted to Buy 3 12-25-2004 09:36 PM
Nitro touring for electric touring iflybyu R/C Items: For Sale/Trade 1 09-28-2003 11:44 PM
