Old 06-21-2006, 07:00 PM   #1
Send a message via AIM to WhoMe
Default Indi Reactor 30 Question.
Ive noticed that on my Reactor thirty..that the fan keep going after the lights go out and the the device *clicks* off. To me the lights going off and the *click* suggests the voltage cutoff has been reached. However the fans continue to run?..this device isnt hooked up to a power supply so Im assuming its further draining a pack thats reached its cutoff? Can somone who has used this device tell me exactly whats going on there.
WhoMe is offline   Reply With Quote
Old 06-21-2006, 07:03 PM   #2
RaceAce701's Avatar
Trader Rating: 86 (99%+)
u are exactly right when the device clocks off it reaches the voltage cut off.
the fan keeps running because it takes very little power to run it and also because the voltage cutoff is not that low.
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 06-21-2006, 07:57 PM   #3
Robertw321's Avatar
R/C Tech Charter Subscriber
Actually the Thirty is wired wrong from the factory. The fan leads are wired to the battery side of the cutoff device not the load side. It will, after time run the battery to 0 volts. The conversion so the fan is on the load side is easy but I will have to dig mine up and look inside so I will remember what I did.
Bob Williams
Robertw321 is offline   Reply With Quote
Old 06-21-2006, 08:56 PM   #4
the fan wont hurt the batts, it only draws out little power.
skamolly is offline   Reply With Quote
Old 06-21-2006, 11:07 PM   #5
Ive disconnected the fan and wired it to my 12volt distributor box. Temporary solution.
Old 06-22-2006, 06:41 AM   #6
do not change the wiring of the fan. because it helps on cooling the reactor after a 30amp linear discharge.
Old 06-22-2006, 07:31 AM   #7
I wired the fan to my PS. Itl run when ever I flip the switch on my distribution block. It just wont run off the battery. I tested a pack that I left on after the lights went out (Fan running in stock config) and it was below its cut-off. IB3800 cells do NOT like to be dropped below a reasonable cutoff. They espcially dont respond well to being dumped completly.
Old 06-22-2006, 03:36 PM   #8
Whome, whats the voltage reading after the cutoff?
Old 06-22-2006, 05:47 PM   #9
Its not reading anything..thats how I know the fans are draining the cells. Because the reactor drains the batteries as a pack and not individually like a discharge tray..when I pull the packs off the reactor (as soon as the lights go off) and put them on my smart tray it continues the discharge much like youd expect. When I leave the pack on the Reactor even after the lights go out I notice the Tray just blinks once and shuts off. Oh and thanks for the roll eyes...shhheeesh.
Old 09-17-2006, 11:35 AM   #10
stumper1's Avatar
Anyone know if there is a way to modify the discharge cut-off? Would like to be able to use this with 4-cell packs too.
[COLOR="Lime"]Deric®[/COLOR]
stumper1 is offline   Reply With Quote
Old 09-17-2006, 10:56 PM   #11
Yeti35's Avatar
There is an adjustable pot inside that is for the cutoff. I never messed with it but my battery guy has but I never asked him how he made out with it. I know he drilled a hole in the front of it for easier access. I will try to remember to ask him when I get back from LV.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-02-2006, 08:22 PM   #12
mudpuppy's Avatar
It is possible to modify the cut off but it won't go low enough to take a 4-cell pack down to 3.6 volts
mudpuppy is offline   Reply With Quote
Old 10-02-2006, 09:26 PM   #13
Yeti35's Avatar
Thanks for the reply Mud, as it was I forgot to ask you about this!!
22 3.0SR
Indi Reactor 20 rccars R/C Items: For Sale/Trade 5 02-02-2008 10:49 PM
Indi Reactor djssafeseat R/C Items: For Sale/Trade 0 11-19-2006 10:20 AM
INDI Octane 2 Discharger 20A Individual & INDI Reactor 30 jrighter R/C Items: For Sale/Trade 6 01-19-2005 09:43 AM
07/01/04 Indi Reactor 30 RandyB R/C Items: For Sale/Trade 6 07-12-2004 06:05 AM
Indi reactor 30 and Indi 16x3 pro v2.5 ni-mh weidjd R/C Items: For Sale/Trade 4 03-31-2004 04:04 PM
